setting timing markets
rdjohnston50
PostPosted: Sun Mar 23, 2008 4:55 am    Post subject: setting timing markets Reply with quote
Ok, an elementary question here but its easier to poll the board then dig thru the textbook.
On an 82 931, do I set the cam timing mark to correspond with the "Z" or the "0" on the flywheel mark?
Seems to me I set it to the "Z".....
Thanks as always....
PostPosted: Sun Mar 23, 2008 5:49 am    Post subject: Reply with quote
Z1 is correct, the O is for ignition timing.
rdjohnston50
PostPosted: Sun Mar 23, 2008 6:07 am    Post subject: timiing marks Reply with quote
Thanks Paul, call it a middle age brain fart......
PostPosted: Sun Mar 23, 2008 6:23 am    Post subject: Reply with quote
So did you buy new followers for that new cam instead of taking a winter vacation?
rdjohnston50
PostPosted: Sun Mar 23, 2008 6:32 am    Post subject: timing marks Reply with quote
That's the next purchase - ouch
By the way, here's another elementary question - the tech manual isn't clear on this point. WHen adjusting the valve clearance, is the cam lobe pointing up or at 9:00? The manual says pointing up but the picture shous the cam at 9:00. Hence my confusion
PostPosted: Sun Mar 23, 2008 6:41 am    Post subject: Reply with quote
There is probably a pretty large area of the base circle with zero lift (and hence a big margin for error), but I would try to have the lobe at 180 degrees from the follower to make the adjustment.
PostPosted: Sun Mar 23, 2008 6:54 am    Post subject: Reply with quote
If you haven't bought new followers yet, what are you up to today?
rdjohnston50
PostPosted: Sun Mar 23, 2008 6:58 am    Post subject: valve adjustment Reply with quote
THanks Rasta,
