mgatlag
Posted: Mon Mar 17, 2008 11:28 pm Post subject: been running great, won't start today... |
Well it's not supposed to rain today so I thought I'd get the 924 out of storage and drive it today but she had other plans...
Normally when I start it, it fires right up and warms up in a few minutes. Today, however, no dice. It fired up and immediately revved up to about 3000 rpm and then died. I tried several more times and almost got it to stay on but it was idling so rough, I thought the engine was going to vibrate out of the engine compartment and fall out. It's never done this. And I mean the engine REALLY was vibrating! I even heard a few bursts of air that sounded like I have NOS and the lines were purging! WTF!!! That only happened 2 times while trying to start though. Needless to say, it stayed in the garage for today. Any suggestions? WUR, injectors, accumulators are all new and never had problems since they were replaced. I've done fuel test recently and all was well, but something is definitely wrong now....  _________________ Michael
'77 1/2 924 N/A- 5 speed Audi box
'04 Ford Taurus - gone!!
'92 Jeep Cherokee Laredo - gone!!
Porsche... better than tea with Miss McGill
(Slap Shot) |
Joined: 29 Jul 2001 Posts: 9129 Location: Royal Oak, MI, USA
Posted: Tue Mar 18, 2008 12:37 am Post subject: |
Condensation in the distributor cap causing misfires? _________________ Vaughan Scott
mgatlag
Posted: Tue Mar 18, 2008 1:01 am Post subject: |
Never thought of that one. If this is the case, is this normal? And what is the remedy or prevention? I have noticed that when I start the car after sitting for a week or so, moisture does spit out the tailpipe at first start up. _________________ Michael
(Slap Shot) |
Posted: Tue Mar 18, 2008 1:53 am Post subject: |
Not all that common - maybe you should stop storing it in the boathouse?
Did that fix it? _________________ Vaughan Scott
Posted: Tue Mar 18, 2008 2:04 am Post subject: |
| mgatlag wrote: | | And what is the remedy or prevention? |
A light misting of WD40 inside the cap can help this issue. _________________ Toofah King Bad
mgatlag
Posted: Tue Mar 18, 2008 2:36 am Post subject: |
Sorry Vaughan but the only thing in the garage is the 924. The 28' cuddy cabin Sea Ray and 67 427 Cobra sit outside all year around, uncovered. I do have my priorities! I'm bored at work today so I think I'll take off the afternoon and play with the 924. I'll try misting some WD40 like Rasta said. This hasn't happened with the car yet, I'm hoping this isn't going to start a trend each time I want to get her out. If this doesn't work, I guess I'll have to start with a fuel flow test and injector spray test and see where that gets me. If you see a big ball of flame from Indy, assume I did something wrong! _________________ Michael
(Slap Shot) |
PORSCHEV
Posted: Tue Mar 18, 2008 3:11 am Post subject: |
I would also inspect the timing belt. Might have jumped a tooth if it getting worn and dried out. _________________ 1976 924
1978-#53 "D" track racer. |
mgatlag
Posted: Tue Mar 18, 2008 8:16 am Post subject: |
Think I figured it out. There was a hose coming off the back of the intake manifold that didn't have a hose clamp and came loose enough to create a vac leak. The burst of air I heard must have been the hose blowing off cuz as soon as I reattached it, it fired right up and ran good. I guess there was more air going thru that hose that I thought. Wish they were all that easy. I did spray some WD40 in the cap and it seemed to start better than normal when the engine is cold. _________________ Michael
(Slap Shot) |
Posted: Tue Mar 18, 2008 6:16 pm Post subject: |
| 924RACR wrote: | | Condensation in the distributor cap causing misfires? |
| mgatlag wrote: | | Never thought of that one. If this is the case, is this normal? |
| 924RACR wrote: | | Not all that common |
...unless you live in the damp UK climate!
Here, it's the number one reason for cars not starting! _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
