no fire
rackhound
PostPosted: Mon Mar 03, 2008 9:18 am    Post subject: no fire Reply with quote
I just bought a 84 944 and am quikly learning alot. My question is this....Ive got 12 volts going to the distibuter cap from the ignition coil but no spark coming out. what could be my problem? Ive already replaced one of the two sensors mounted to the intake, and the other was good. any help would be appreaciated.
View user's profile Send private message AIM Address Yahoo Messenger
PostPosted: Mon Mar 03, 2008 12:50 pm    Post subject: Reply with quote
Welcome to the board. Here's a great place for 944 info:
http://www.clarks-garage.com/
Trouble shooting for your issue is here:
http://www.clarks-garage.com/shop-manual/ts-01.htm#fire
PostPosted: Mon Mar 03, 2008 6:29 pm    Post subject: Re: no fire Reply with quote
12 V on the king lead? That's not right! Sounds like you've got a shorted coil.
rackhound
PostPosted: Tue Mar 04, 2008 10:25 am    Post subject: Re: no fire Reply with quote
Glad I found this place I know its not a 944 board but it seems like a good place and you guys really know what your talking about. A guy at the autobahn.com told me I should try here.
If my speed sensor and reference sensor had gotten switched around by mistake would this cause my problem?
I would just switch them to find out but im not sure if it would cause other problems if I did this and its not the problem.
PostPosted: Wed Mar 05, 2008 5:40 pm    Post subject: Reply with quote
I'm out of my depth with 944 speed and reference sensors.
I suggest you follow one of Paul's links to find someone with experience closer to your area...
Rich H
PostPosted: Wed Mar 05, 2008 11:02 pm    Post subject: Reply with quote
Again no idea about '44s but as above, there should not be +12V on the dizzy cap. There should be +12V to one side of the coil and then the coil is triggered by earthing it, normally carried out by the ECU, but that depends on the setup. On a '24 its done by the Transistorised Control Unit, on a '44 I have no idea.
I would start with another coil and see what happens.
Good Luck
Rich
rackhound
PostPosted: Mon Mar 10, 2008 12:24 am    Post subject: Reply with quote
Good Luck
Rich
I swapped coils and dmes with known good ones and did a resitance check at the plug that goes into the back of the dme and found out that im not getting a good connection at the speed sensor connection on the back of the intake. hopefully today ill have it running.
rackhound
PostPosted: Mon Mar 10, 2008 8:44 pm    Post subject: Reply with quote
Finally got it running. Thanks for the help.
PostPosted: Mon Mar 10, 2008 9:30 pm    Post subject: Reply with quote
What was it?
PostPosted: Tue Mar 11, 2008 12:01 am    Post subject: Reply with quote
A duff 944!
rackhound
PostPosted: Tue Mar 11, 2008 9:02 am    Post subject: Reply with quote
was the speed sensor, it wasnt getting a good connection at the plugin. I filed some corosion off and plugged it back in then had to tap on the fuel pump to get it running. The car sat for 5 years in a garage before I bought it.
PostPosted: Tue Mar 11, 2008 9:04 am    Post subject: Reply with quote
Check the timing belts, a lot of us replace them every 3 years or 36000 miles.....
