Petrovich
Joined: 27 Sep 2005 Posts: 235 Location: Rockville, MD
Posted: Tue Mar 11, 2008 3:08 am Post subject: 931 fuel map for Megasquirt |
Can somebody with a relatively unmolested 931 post their VE table? (-Nick?...) _________________ 1982 924 Turbo, now Lemon |
Min
Posted: Tue Mar 11, 2008 3:23 pm Post subject: |
Use the generated fuel map you get by typing in your motors specs/hp into the VE table generator. every car is different, variables like what kind of fuel pressure regulator and the diaphram response time will heavily change the curve. You do not want to use another person's map, it will be wrong for your motor and could damage things, start from scratch and tune your own table, It really won't take very long if you have a wideband oxygen sensor (which you should absolutely have on a turbo car)
macBdog
Posted: Tue Mar 11, 2008 5:15 pm Post subject: |
You can't really use someone else's map. Different injectors and other bits of hardware make all the difference. If you don't have a reliable AF reading it will be extremely difficult. I got my car to idle and drive without one before I thought "screw this, I'm getting me a wideband!" _________________ 1979 931 with a 350 chev
1973 911E with EFI
Rich H
Posted: Tue Mar 11, 2008 7:39 pm Post subject: |
OK mine is an N/A but what they say is true, get a WB, check all of your senders are accurate and then, tune tune, tune!
If any of your senders are suspect then fix them now. It will screw everything up in the long run. My IAT sender was out of cal by 10 degrees and that screwed up my VE table as the MS though the air was less dense than it really was. I figured I would fix it later, when I did then I had to start tuning again from scratch  _________________ 1994 Lotus Esprit S4 - Work in progress...
Petrovich
Posted: Wed Mar 12, 2008 12:37 am Post subject: |
I do have a wideband; it's just that every time I generate a map, it's grossly off I was hoping that I can look at another person's map to make sure that proportionally, my map is alright. At the moment, I only have near-idle and N/A settings OK, but I'm about to start going into boost. _________________ 1982 924 Turbo, now Lemon |
Min
Posted: Wed Mar 12, 2008 1:35 am Post subject: |
| Petrovich wrote: | I do have a wideband; it's just that every time I generate a map, it's grossly off I was hoping that I can look at another person's map to make sure that proportionally, my map is alright. At the moment, I only have near-idle and N/A settings OK, but I'm about to start going into boost. |
If its grossly off, that usually means one of your initial settings is incorrect. What you should do, is create a generated table, and then use your required fuel number to adjust the generated table until you get approximately 13.5:1 at idle reading on your wideband, this should put the rest of the table approximately were it should be, and will make tuning the table easier. Save a msq first though so if you can't get it working properly you can always go back to what you have right now.
flosho
Posted: Fri Mar 14, 2008 1:32 pm Post subject: |
Just curious what size injectors everyone is running and their req_fuel and injector method (simultaneous/alternating). _________________ [This Space For Rent] |
Min
Posted: Sat Mar 15, 2008 1:41 am Post subject: |
| flosho wrote: | | Just curious what size injectors everyone is running and their req_fuel and injector method (simultaneous/alternating). |
I'm running 21 pound blue top high impedance ford injectors, 2 squirts alternating, but I'm going to be changing that when I upgrade to ms2/extra code when the new version is released.
Petrovich
Posted: Sun Mar 16, 2008 1:55 pm Post subject: |
WOHOOOO
Thank you all.
I just finished my first on-boost run (thirteen-to-one AFR ratio, on average). Builds up to 142 KPA, after that I stopped pushing the go pedal.
The fix to my idling was setting injectors to 2 squirts alternating. I'm using what's supposed to be 36lb/hr injectors, but they're way rich all over the map. Getting idle with 4 sqirts alternating was next to impossible, as it was either 12-1 AFR, or stall. 2 squirts actually allowed me to use the generated table after leaning it out a bit and then leaning out the idle section some more.
IIRC my req_fuel is 5, or something of that sort.
A bit more testing tomorrow, and then I'm off to the sunny Puerto Rico for a week. Just when I get things working... _________________ 1982 924 Turbo, now Lemon |
Petrovich
Posted: Mon Mar 17, 2008 12:15 pm Post subject: |
150KPA! 6500 RPM!
Now, let me rephrase my original question....
Can I have somebody's SPARK table?  _________________ 1982 924 Turbo, now Lemon |
Min
Posted: Tue Mar 18, 2008 2:42 am Post subject: |
Hopefully someone with a 931 running megasquirt can give you their spark table. Nick?
