Adjusting CO2 what kind of tool do I need
Dutch924-racer
PostPosted: Fri Jan 25, 2008 6:21 am    Post subject: Adjusting CO2 what kind of tool do I need Reply with quote
For adjusting CO2 the say you need a special tool in the Haynes manual, what kind of tool do I need ?
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
PostPosted: Fri Jan 25, 2008 7:54 am    Post subject: Reply with quote
All you need is a long 3mm hex wrench.
Depending on the model year of the car, here in the U.S. there may be a plug in the hole for the CO adjustment which must be pressed out from the bottom side of the air flow sensor unit, or drilled out, or may just have a rubber plug on a stick stuffed in it.
No matter what you have, you need to plug the hole when you are done, because the leak through the hole will affect the CO.
