Special Tools
Chrenan
PostPosted: Tue May 20, 2008 4:34 am    Post subject: Special Tools Reply with quote
This has come up a few times, what special tools are required to work on the 924. I've got pictures of a few of mine below, feel free to add. Some of these aren't required, but they sure are nice to have. And yes, I know you could accomplish the same thing using a flat blade screwdriver, a claw hammer and a pipe wrench. But seriously, if you can't take the time or commit the money to buy a few nice tools, maybe you shouldn't own a Porsche.
I have seen some very creative home made special tools by 924Board members, hopefully some of those will get posted.
Tool to loosen the rear axle nut:
Tool to remove the injectors:
Tool to adjust the timing belt tensioner (modified for clearance):
Tool to remove the triple-square nuts on the half shafts:
Tool to set the rear toe:
Vintage German made metric thread pitch guage (OK, not required, but cool and handy):
PostPosted: Tue May 20, 2008 4:54 am    Post subject: Reply with quote
I have most of those that you posted, plus I have:
    - one of the valve adjustment sockets with the 3mm alan head
    - the 17mm socket for removing the gearbox plugs
    - a piece of above-mentioned socket that I cut off with a die grinder so I can use it with a box wrench to remove the top plug on a snailshell without pulling the trans
    - a modified screw-driver for disassembling the fuel sending unit as described in Vaughan's writeup.
I don't have pix handy, but maybe I'll get around to posting 'em later on tonight...
PostPosted: Tue May 20, 2008 1:12 pm    Post subject: Reply with quote
One of those really long t-handled mini allen wrenches to adjust the fuel mixture at the dizzy...
Oh, and one of those really short mini allen wrench sockets to adjust the valve lash.
bcblase
PostPosted: Tue May 20, 2008 2:02 pm    Post subject: Reply with quote
I can't claim that I made any of these, but if you have a 924S,
you'll need some of these:
1. "Kriket" timing belt tensioning tool
2. 28 mm bent thin wrench
3. Pin spanner wrench for balance shafts
4. 8 mm triple square/cheesehead socket
5. Big-ass socket for driving wheel bearings & races
6. 32 mm socket for rear axle nuts
7. Flywheel lock for working on belts
8. 17 mm hex for tranny plugs
Hope this helps,
BC
1987 Porsche 924S - track toy
2001 BMW 325xi - daily driver
PostPosted: Tue May 20, 2008 5:10 pm    Post subject: Reply with quote
Plus:
A CIS fuel pressure test set
a deep-offsest 22 mm ring spanner (wrench) for front strut top-nut
And an alternator hook for adjusting the belt tension.
Oh, and a triple-jointed spark-plug wrench for getting the m...f... plugs in and out!
tux
PostPosted: Sat May 24, 2008 6:36 am    Post subject: Reply with quote
Mike924 wrote:
Plus:
.......And an alternator hook for adjusting the belt tension......
Sorry not got anything constructive to add to this, but that is a top tool! Beats the hell out of using a pry bar.
Pete
Merlin Guards Red 1985 N/A
PostPosted: Sat May 24, 2008 2:22 pm    Post subject: Reply with quote
Real men don't need a pry bar to tension a 924 alternator belt.
tux
PostPosted: Sat May 24, 2008 8:41 pm    Post subject: Reply with quote
Which is exactly why I need one of those tools!
Pete
PostPosted: Sun May 25, 2008 1:41 am    Post subject: Reply with quote
No doubt, Paul. My arm came with an alternator hook pre-installed.
PostPosted: Fri May 30, 2008 5:18 pm    Post subject: Reply with quote
Almost forgot:
Pointed M10 bolt for centering the steering rack.
moone924
PostPosted: Fri May 30, 2008 5:59 pm    Post subject: Reply with quote
not to forget triple square for head bolts or allen for early bolts
Ryan Moone
New philosophy : one car project at a time.
Vince Ponz
PostPosted: Sat May 31, 2008 12:54 am    Post subject: Reply with quote
Removing the rear glass or spoiler. Get an old screwdriver and cut a groove in it. Simple and cheap.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
