Dutch924-racer
Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
Posted: Thu Nov 22, 2007 8:03 pm Post subject: will 944 wheels fit on 924 turbo ? |
Will 944 wheels (15" 7J phone dail wheels) fit my 924 turbo (79' 5-stud) without the use of spacers ? _________________ 937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
Forge recirculation valve + boost controller |
peterld
Joined: 10 Dec 2006 Posts: 987 Location: Noosa Heads QLD Australia
Posted: Thu Nov 22, 2007 10:50 pm Post subject: |
| There are two types of 944 'phonedial' wheels. If you select the up to 85.5 year models then they are a straight bolt on fit - the early 944s after all had identical suspension to 924Ts. Another straight bolt on fit are 'cookie cutters from the same years. |
Maxx
Joined: 19 Apr 2004 Posts: 10 Location: Eskilstuna, Sweden
Posted: Fri Nov 23, 2007 1:33 am Post subject: |
No, wheels from an early 944 will not fit on a 924 turbo. Wheels for a 924 turbo have an offset of 52 mm and wheels for 944 before -87 has an offset of 23 mm (944 has a wider track!).
Wheels from -87 and later, with a higher offset, will fit perfectly. _________________ //Maxx |
Dutch924-racer
Posted: Fri Nov 23, 2007 2:27 am Post subject: |
So I need phone dail wheels from a 944 type 2 ? Sure ? And do the exist in 15 inch ? _________________ 937 trackday car
Series 2 engine
Fast road camshaft
Posted: Fri Nov 23, 2007 4:47 am Post subject: |
just pay attention to the offset as maxx stated, you'll be fine, and yes they do come in 15 (on my 924S) _________________ Toofah King Bad
peterld
Posted: Sat Nov 24, 2007 12:24 am Post subject: |
Sorry guys - you are so right. Too late at night when I wrote that. Just got so excited - kinda like premature vocalisation. Only had to walk into my workshop to confirm. Forgot that operative word 'spacers'. Mea Culpa.
Cheers Pete |
Dutch924-racer
Posted: Sat Nov 24, 2007 2:59 am Post subject: |
after some research:
924 turbo 15x6J offset 53 (spiderweb wheels)
924 S phone dail 15x6J or 15x7J offset 52,3
944 I phone dail 15x7J offset 23,3
944 II phone dail 15x7J offset 52,3
So I need 944 II or 924 S, of course I will look for the wide 7J ones.
Does 944 II have a different offset front/ rear ? _________________ 937 trackday car
Series 2 engine
Fast road camshaft
Posted: Sun Nov 25, 2007 4:06 am Post subject: |
I think some had an offset of 10 in the rear (turbo? S?). _________________ Toofah King Bad
flosho
Posted: Sun Nov 25, 2007 10:13 am Post subject: |
All the late model 87+ 944s had 52.3mm offset front and rear. _________________ [This Space For Rent] |
Raceboy
Posted: Sun Nov 25, 2007 4:57 pm Post subject: |
Early offset 944 wheels fit just fine on 924 Turbo, of course it depends on the width of the rim/tire. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Dutch924-racer
Posted: Sun Nov 25, 2007 6:32 pm Post subject: |
Well I want 7J wheels, the 6J spiderweb wheels are to small for my slicks.
I think the telephone dail 944 S2 wheels will be the best option for track use, don't you think ?
I want to stick to 15" because I have all my slicks/ rain tires in that size. _________________ 937 trackday car
Series 2 engine
Fast road camshaft
Raceboy
Posted: Sun Nov 25, 2007 7:10 pm Post subject: |
On the track you want as much track as you can. In case of 7", early offset wheels should fit fine. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
patand
Posted: Sat Dec 15, 2007 3:31 am Post subject: |
| Raceboy wrote: | | On the track you want as much track as you can. In case of 7", early offset wheels should fit fine. |
That is correct! I run 15x7" Cookie Cutters ET23 with 205/50-15 R-tires for track use. It fills out the body nicely but you might need some tracksettings (which I have on my car) for the camber for them to stay within the wheelarches.  _________________ www.patandracing.se |
Dutch924-racer
Posted: Sat Dec 15, 2007 7:12 am Post subject: |
I bought a set of phone dail wheels.
front, 15x6J ofset 36 (from 911)
rear, 15x7J ofset 52,3 (from 944 S2) _________________ 937 trackday car
Series 2 engine
Fast road camshaft
