RC
Posted: Fri Dec 07, 2007 8:48 am Post subject: WTF is this tool for? part 2 |
Lets keep the game going.
What would you use this set up for?
Roger |
joecitizennn
Posted: Fri Dec 07, 2007 9:14 am Post subject: |
nose hair trimming _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
Chrenan
Posted: Fri Dec 07, 2007 9:37 am Post subject: |
Installing oil seals? _________________ 1987 951 - M193 Version for Japan |
joecitizennn
Posted: Fri Dec 07, 2007 10:45 am Post subject: |
porting _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold |
Min
Posted: Fri Dec 07, 2007 11:00 am Post subject: |
Looks like something I would use to change valve springs. Not that the diegrinder would be included in that.
!tom
Posted: Fri Dec 07, 2007 11:03 am Post subject: |
Bearing race insertion and/or removal tool? _________________ 78 924 NA
5-lug |
RC
Posted: Fri Dec 07, 2007 8:28 pm Post subject: |
| joecitizennn wrote: | | nose hair trimming |
HA Ha ha
Prefer the LONG NOSE pliers myself, but that would certainly improve the air flow.
Been some good guesses there but no one has got it yet. The die grinder is used here. Maybe a clue in the first WTF is this tool thread.
Roger |
!tom
Posted: Sat Dec 08, 2007 3:00 am Post subject: |
Clearly this is the jig you used to trim the lip off your spring retainers. The flange on the die grinder stabliizes the tool on the end of the cylinder, while the spring retainer is held in the other end and is ground down. _________________ 78 924 NA
5-lug |
RC
Posted: Sat Dec 08, 2007 9:32 am Post subject: |
| !tom wrote: | | Clearly this is the jig you used to trim the lip off your spring retainers. |
No, sorry !tom but youre getting warm.
| Quote: | | The flange on the die grinder stabliizes the tool on the end of the cylinder, |
Yes, exactly.
| Quote: | | while the spring retainer is held in the other end and is ground down. |
Not the spring retainer.
Roger |
Posted: Sat Dec 08, 2007 9:42 am Post subject: |
Then how about -
For grinding the ends of the valve stems?
-And the cylinder's got paper taped around it in the first pic to keep particles out of the cyl head.. _________________ "..it's made in Germany. You know the Germans always make good stuff."
RC
Posted: Sat Dec 08, 2007 10:15 am Post subject: |
| Smoothie wrote: | Then how about -
-And the cylinder's got paper taped around it in the first pic to keep particles out of the cyl head.. |
YES Smoothie, now you`re barking up the right tree.
Thats exactly what its for. 1 1/2" tube is a perfect fit in the lifter bore and the top of an old 35mm film (remember that stuff?) canister is a tight fit in the tube. A 8mm hole punched in the centre is a good seal around the 9mm valve stem.
Took it easy with the grinder in small circles then vacuumed out, cleaned thoroughly with a lightly oiled rag and special foam tipped buds used mainly for cleaning video heads. Final blow with the air gun and I trust no grit got in my engine.
Another of those new cam, new lifters, seats cut, valves lapped, and leave it high to take up the clearance on the old reground cam/lifters PITA situations. Needed at least 11thou clearance but could only get 3, on some exhaust valves, that were sunk slightly more for a wider seat. Took them down about 0.2-0.3 mm and about .1 (4 thou) on the inlets to face out the gouges left by the adjusting screws. Made them all quite consistent and had from 15-18 thou with the screw at a minimal safe point.
Readily admit this problem had me scratching my head but after a few beers and a good night sleep came up with this idea for a useful way to waste the rest of the weekend. Amazed how well it worked too, and am very happy with the result.
Roger |
