Sensor question - engine sensors
3d914
PostPosted: Tue Dec 04, 2007 11:34 am    Post subject: Sensor question - engine sensors Reply with quote
Doing some routine maintenance on my 87 - 924S, I noticed two sensors in the head near the front of the engine (drivers side). One has a single wire, the other has a connector. Which is which? I could not find either in the PET or my Haynes manual.
The single wire had a resistor in line before the spade connector. I suspect this is the Head Temp sensor and someone was trying to filter the output signal to the ECU. Is this typical, and if not why do it?
TIA,
Gerard
Gerard
74-914 2.0L Ravenna Green
87-924S 2.5L Alpine White
John Brown
PostPosted: Wed Dec 05, 2007 11:26 pm    Post subject: Reply with quote
No time to check references now; so from memory:
The front single wire is to the temp guage. Resistor? Maybe someone trying to fool the guage reading?
Rear to the DME computer.
John
80 931 - #931 44Cup
99 Escalade - tows track cars
