Prem baby in hospital and car now playing up
Kerry
PostPosted: Sun Dec 02, 2007 4:58 am    Post subject: Prem baby in hospital and car now playing up Reply with quote
Hi, my husband and I have a very prem baby (24 weeks) in hospital (90 mins away) and need to find out what is going wrong with our 1980 924 so we can get to see our son every day. Below is the problems we've been having, please can anyone suggest what my husband needs to check/do bearing in mind his mechanical knowledge is limited.
1. Started out for hospital with wipers and heater going after about 3 mile volt guage started dropping and elecs slowed down. Turned round to return home by time arrived volts read 0 on guage. Turned car off then couldn't restart due to flat battery.
2. Recharged battery overnight and managed to get her to a garage with volts dropping slowly. Was advised to get new alternator as battery checked out ok. Put new alternator on next day but still lost volts and battery draining flat.
3. Back to different garage where found new alternator faulty so mechanic kindly repaired and refitted it (repaired old one also!). Volt guage was nicely back in green again.
4. All fine for 2 days then car wouldn't start!! Battery fully charged, turning over but not firing. Managed to easily start her with bump/push and she made the journey to hospital and back again with no problem starting.
5. Next morning wouldn't start again unless given a push up the bum! Coming back from hospital in dark had to use lights, heater and wipers which caused volt guage to drop to 12 at 2000 revs and above and 10 when idling at 600 revs. Volts go back up to about 13 when moving with no elecs on.
I think thats everything....please can someone help point us in the right direction as to whats up with her.[/b]
PostPosted: Sun Dec 02, 2007 5:18 am    Post subject: Reply with quote
Welcome to the board and congrats on the new addition to your family.
I'd check the following (I'm including obvious items just to be thorough):
Alternator belt tension
Alternator bushings
Alternator ground wire
Battery clamps
Small red wires that attach to the + battery clamp
Alternator wiring from the alternator to the starter and from the starter to the battery.
Ignition switch (it's a $10 part)
Chrenan
PostPosted: Sun Dec 02, 2007 5:23 am    Post subject: Reply with quote
Congrats on the new baby, sorry to hear the arrival was early.
Paul's info is bang-on, as usual, he is very experienced with these cars.
Erratic gauges are often a grounding issue, the engine ground on the exhaust side of the motor which connects to the large frame rail is often a culprit. The ground wire can come loose or just become suspect with age. Easy to replace and a cheap as well.
Kerry
PostPosted: Sun Dec 02, 2007 5:28 am    Post subject: Reply with quote
Thank you for quick reply and the congrats. . The kind mechanic at the VW garage checked the first 3 on your list. Will get hubby to check the rest. After looking round the forum, I was wondering if there is a timing problem and if so can that cause any of our problems? Should the revs be as low as 600 when idling (excuse my ignorance if thats a daft question...I am blonde after all )?
Kerry
PostPosted: Sun Dec 02, 2007 5:38 am    Post subject: Reply with quote
Thanks Chrenan, will check that also. Hubby becoming more like a mechanic everytime he comes out from beneath the bonnet He's even got the wounds to prove it, he now knows how hot the manifold gets!
joecitizennn
PostPosted: Sun Dec 02, 2007 6:48 am    Post subject: Reply with quote
does not sound like a timing problem. Kind of odd that the car cranked while refusing to fire at one point, but began running with a push start. Has that happened more than the one time you mentioned?
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
PostPosted: Sun Dec 02, 2007 6:53 am    Post subject: Reply with quote
it should idle around 850 rpms,
With the volt guage dipping when you turn the lights and other accesories on, that is normal, with the car idling, turn everything on and measure at the battery with a volt meter, if it is below 13 V, you have a problem.
regarding starting it requiring a push start, I would mimic Paul's suggestion in replacing the ign switch first. after that it is checking broken wires, etc. However next time it happens, have someone listen to the fuel pump while cranking, is it coming on when you are cranking?
If it is then the issue is getting power to the ign module when cranking the car (circuit 50 iirc) there should be a wire running from the starter to the ign module which does this. Check there as well (will need a haynes wiring diagram).
3 928s,
PostPosted: Sun Dec 02, 2007 7:10 am    Post subject: Reply with quote
Also, (the mech should have done this, but..) check the charging system light in the dash. With ignition switched on, but engine not running, the light should be on. It's part of the "exciter circuit" which tells the alternator to start charging. If that bulb is burnt out or otherwise not working due to faulty wiring, etc., the alternator won't go into charge mode.
-And if the light stays on while the engine is running, that indicates a problem as well..
PostPosted: Sun Dec 02, 2007 7:42 am    Post subject: Reply with quote
The charging system sounds ok and volts will drop under load to around 12 as you said.
my 2c.- Battery is cactus.
Cold weather destroys batteries.
Chrenan
PostPosted: Sun Dec 02, 2007 10:00 am    Post subject: Reply with quote
The timing on these cars doesn't usually cause issues unless you've recently changed a timing belt or moved the ignition distributor in its housing and screwed something up. Otherwise, it should stay constant. The timing belt could be loose but I doubt that's the issue. Easy to check, twist the timing belt with your thumb and first finger (with the car not running!), if you can just twist it 90 degrees the tension on the belt is OK.
Tigger937
PostPosted: Sun Dec 02, 2007 10:11 am    Post subject: Reply with quote
That low idle may be part of your problem as it's barely enough for the alternator to maintain battery voltage, especially with all your accessories turned on. I'd start by correcting that first and making sure the belt is tensioned properly (should have no more than 1/2" deflection in the middle between 2 pulleys).
Is this a 924 Turbo by chance? I ask because of your questions about timing. The idle on the turbo is set with a timing light.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
Buwani 931
PostPosted: Sun Dec 02, 2007 10:28 am    Post subject: Re: Prem baby in hospital and car now playing up Reply with quote
Ok,let me start by saying I am sure you will get great advise from the knowledgable members here to get your car more reliable. I love my 924 and it has never left me stranded (knock on wood ). BUT , I would not feel comfortable with having it as my only daily driver for a wife and a delicate newborn especially if he was a bit mechanically challenged. I am assuming this by the first part of your message, perhaps I am wrong.
If for some reason my transmission went out, or turbo or timing belt breakage, I would be up a creek for some time. Luckly I have other cars but it sounds like you might not.
Dont get me wrong, a 924 can be a very reliable car but one with issues and a family relying on it, might not be your best choice.
Do you have child seat laws in the U.K.? In the U. S., the baby seat must be put in facing backwards. I can't imagine putting a family of three in my 924.
Congrats on the newborn and I hope all goes good.
Shawn
PS I hope I dont get flamed but feel free to let it rip if you see fit.
That's thirty minutes away. I'll be there in ten.
Kerry
PostPosted: Mon Dec 03, 2007 7:01 am    Post subject: Reply with quote
Thanks to all who have replied, very much appreciated. We do also have another more practical family car....a '68 morris minor , unfortunately she's waiting patiently for a new engine . As we never really travel more than 10 miles, the 924 (not turbo) was never really a problem even with 4 children...hubby loves car so much he'd do 2 trips!! Regarding child restraints, our local policeman told us the 4 point harnesses in the rear were safe and legal. Obviously if we do ever put a baby seat in, it will go in the front passenger seat. Plan is to get morris back on road, sell and get another car (Datsun 280ZX maybe )
Joe asked about the bump starting....it only needs bumping once in the morning then starts up fine after that until its been left standing for more than about 5 hours. However it started first time this morning after standing all night, could it be a cold start problem as weather was much milder today. [/code]
joecitizennn
PostPosted: Mon Dec 03, 2007 8:59 am    Post subject: Reply with quote
I would not think that having to bump start the car every morning was odd, if the reason behind it was an inoperative starter. But you said the starter cranked the engine fine, the car just would not fire up. So why then would it decide to fire with a push start? If the engine runs with a push start, then it should run from the starter cranking it.
I am not up up on early 924 electronics, so maybe someone else can come up with a reasonable explination. Is it possible that the cranking of the starter causes such a voltage drop that the ignition does not have enough juice to fire?
Have you checked your spark when trying to crank the engine with the starter? It is simple to check, and the color and size of the spark can tell you alot about the health of your ignition system.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold
RC
PostPosted: Mon Dec 03, 2007 9:38 am    Post subject: Reply with quote
Joecitizennn wrote:
Yes it is possible but the starter circuit is designed to apply !2V from starter # 16 to the primary ignition resistor, therefore giving a voltage "boost' during cranking. If the battery is fine and the car cranks OK this will likely be faulty.
I would suggest that hubby first check and clean (scrape with screwdriver, points file) the connector terminals at the 3 pin plug & socket at the top rear of the firewall, near the brake booster. This carries the power from the starter to the resistors during cranking and is a known failure point due to corrosion and age.
Also check the wiring and connectors at the coil and the resistors. Check the resistors for continuity if he has a meter or a test light. Also make sure there are 2 small wires connected on the starter solenoid.
Best of luck with the car(s) and your newborn.
Roger
