924rennsport
Posted: Sat Feb 28, 2009 3:59 pm Post subject: BMW 1.9 in a 924 |
Just a brainstorm.
I recently drove a friend's BMW Z3 with the 1.9L 4 cylinder and a Downing Atlanta (I think) supercharger kit. I was looking at the engine and thinking...
Could a BMW engine be transplanted into the 924?
If only BMWs used the Audi bolt pattern... _________________ - Brian |
Posted: Sun Mar 01, 2009 6:44 am Post subject: |
As some have said in the past.....
....anything's possible with enough time and money.
Like any engine swap into the 924/944 you need a bellhousing to adapt it to the torque tube. A clutch/flywheel that will work with the starter and the input shaft from the transaxle. After that you have to fit it in the engine bay, so mounts, possible oil pan clearance, hood modifications, etc. _________________ Stefan
das push
Joined: 27 Oct 2005 Posts: 53 Location: cincy, oh, usa
Posted: Fri May 08, 2009 4:48 pm Post subject: |
curious do the Z3 engines sit in the car on an angle like the 924. helped a buddy with his 77 320i the other day. was amazing the similarities in the engine compartment. the engine was in on angle and it was Bosche CIS. If the Z3 sits in the same this could be a practicle application. _________________ 1982 924 NA 85K owned since 1992
82 nicknamed das push"the push"by my kids.
lots of electrical problems 1st yr of owner ship! |
Jeremy924
Posted: Mon Oct 07, 2013 3:08 pm Post subject: |
+1 _________________ 1981 924 N/A
1999 Suburban 454
1989 BMW 525I |
Posted: Tue Oct 08, 2013 5:14 am Post subject: |
Supercharged Porsche 2.5 would be much easier. _________________ Toofah King Bad
ernestborden
Joined: 18 Mar 2014 Posts: 1 Location: 169 Ruckman Road Dover, OK 73734
Posted: Wed Mar 19, 2014 2:58 pm Post subject: Re: BMW 1.9 in a 924 |
| 924rennsport wrote: | Just a brainstorm.
If only BMWs used the Audi bolt pattern... |
Certainly Brain,I too drove BMW Z3 I was mesmerizing.I think they have replaced BMW Control Arm & Suspension Bushings because usually this vehicle will start showing significant vibration around 50 miles per hour but I couldn't find such issue,I found the drive was very smooth like a butter. |
GeorgeV
Joined: 14 Mar 2010 Posts: 306 Location: Brisbane, Australia
