924aussie
Joined: 02 Feb 2006 Posts: 1009 Location: Chinchilla Queensland Australia
Posted: Mon Dec 03, 2007 12:32 am Post subject: Car interior Shampooer ( Machine ) |
Can anyone recommend a Car interior Shampooer.
I want to be able to "shampoo' the interior of the 924.
Alan _________________ green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1980 Fire truck Sold |
Posted: Mon Dec 03, 2007 12:59 am Post subject: |
I just use a spray bottle of soap-water solution, a brush, and a wet/dry shop vac. Spray, brush, vac, then change to straight water in the bottle and spray, and vac to rinse. Vacuum thoroughly to pull out as much moisture as possible, then let it air-dry the rest of the way.. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Neil924
Posted: Mon Dec 03, 2007 2:48 am Post subject: |
| Yeah, Smoothie is right, putting chemicals in and old worn carpet isn't a good idea. Just use a little carpet cleaner/ soap and gently scrub it in, vacuum it out and if it's cold or cool out side, go for a dive in the car with the heat on and it venting to the floor. Try to get as much moisture out as possible. |
