Rich H
Posted: Mon Nov 26, 2007 3:41 am Post subject: EFI question... |
Hey guys,
One for the EFI wizards:
What is the best way of getting plug leads to fit the EDIS coil unit? I have a nice set of nearly new BERU leads complete with nice heat shields I would like to keep but they don't fit the coilpack. The dizzy end plugs screw off, can they be replaced easily with the right plugs?
Or do I just replace the lot?
Cheers
Rich _________________ 1994 Lotus Esprit S4 - Work in progress...
Min
Posted: Mon Nov 26, 2007 3:54 am Post subject: |
I just bought some EDIS plug wires.
Lizard had some made up custom at a local plug wire manufacturer. (aurora)
I'm sure you could make up a set with what you've got, but you'd have to find the coil plug ends someplace. I wasn't able to find any myself.
Rich H
Posted: Mon Nov 26, 2007 4:10 am Post subject: |
Fair enough, I'll file the BERU ones for now then.
Cheers
Posted: Mon Nov 26, 2007 6:13 pm Post subject: |
So, Rich, you doing the squirt and spark all in one go, eh?
I'd try getting the EFI running on standard ignition, then go over to the EIDS.
But, then, I'm a bit of an old woman.  _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Rich H
Posted: Mon Nov 26, 2007 8:10 pm Post subject: |
Yeah, I should really, but its going to be a fair amount of work to get it running full stop then another load of work to change everything over...
What I might do is get everything in place but not connected up. Get it running on a single coil then change over to EDIS
I need to re-wire the MS too to get it to work. Means the car will be off the road for a bit longer now but alot less when I change to EDIS.
That is if I can get it to run!!  _________________ 1994 Lotus Esprit S4 - Work in progress...
