Intank Fuel Pump Torque
isuras2
PostPosted: Mon Nov 26, 2007 9:04 am    Post subject: Intank Fuel Pump Torque Reply with quote
I replaced the rubber seal on the intank fuel pump. It stopped the leak for about 2 months, then the fuel started to leak. I tightened it up a little and it leaked again. Now I drained the tank and made sure each surface is free of foreign material and tightened the fuel pump by hand until the rubber surfaces met, then just a tad more. It doesn't leak now, but is there a torque that it should be at?
The wiring to the pump only connects to one side of the fuel pump, e.g. positive wire to positive on pump, negative wire to negative on pump and NOT vice versa?
Thanks,
Rob
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Mon Nov 26, 2007 6:10 pm    Post subject: Re: Intank Fuel Pump Torque Reply with quote
Errm... that sounds right to me...?
isuras2
PostPosted: Mon Nov 26, 2007 10:50 pm    Post subject: Reply with quote
I guess what I meant was there is no way to switch them? Like the size of each post is slightly different so the wires cannot be switched.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Tue Nov 27, 2007 12:00 am    Post subject: Reply with quote
That's certainly true of the main pump, but I'm not sure about the in-tank pump.
