dash16
Posted: Fri Nov 23, 2007 9:30 am Post subject: Disconnect power to the antenna |
I finally figured out how to get my broken ass antenna to retract (a bit tricky) and i want to keep it retract. Therefore, how do i disconnect it so that i don't have to deal with it anymore? thank you lots _________________ 1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS |
dash16
Posted: Fri Nov 23, 2007 11:02 am Post subject: |
i turned the antenna switch to off and then i disconnected the switch. done _________________ 1987 Porsche 924S Black/Black. 5-spd.
924guy
Posted: Fri Nov 23, 2007 11:09 am Post subject: |
there sure be a power fuse, not sure which it is though. if you cant find it, the
power wire connection should be behind the carpet on the drivers side left kick panel..somewhere behind the hood pull lever. its buried in there pretty good.. _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
