Dan
Joined: 27 Apr 2008 Posts: 24 Location: Great Yarmouth, UK
Posted: Tue May 06, 2008 10:54 am Post subject: Cam-follower |
I'm trying to show the flat of the Grub which are bottom most in the picture, and the Grubs trajectory in relation to these flats, which way is correct?
Allan key adjustment through the higher or lower hole
 _________________ Dan
1979/924 N/A
Street Racer KTA508V
©2008 |
John Brown
Posted: Tue May 06, 2008 1:15 pm Post subject: |
The flat needs to be parallel to the cam. And the tip of the valve. The valve tip presses against the flat of the adjuster so that flat and the valve tip must mate full surface. The picture on the right. _________________ John
80 931 - #931 44Cup
99 Escalade - tows track cars
Posted: Tue May 06, 2008 1:52 pm Post subject: Wrong Place to Discuss 924 Mechanical Lifters |
| This topic needs to moved to the correct discussion area. |
Dan
Posted: Tue May 06, 2008 5:56 pm Post subject: |
Thanks John thats next job quite important to be right I thought
>>this topic needs to moved to the correct discussion area
Wheres the correct discussion area for mechanical help, its not clear, hasn't the 924s not got the cam followers, I'm discussing?
Cheers for your helpful advice though 'gohim'  _________________ Dan
1979/924 N/A
©2008 |
Posted: Tue May 06, 2008 6:05 pm Post subject: |
No, the 86-88 924S has the same 2.5L engine as a 944, and it has hydraulic lifters. This is a completely different engine design, sharing no parts with the 924 2.0L engine.
You are asking about the mechanical lifters used on a 76-85 924 2.0L engine. The correct place for this discussion is the General Discussion Section where 924 2.0 mechanical issues are discussed. |
Dan
Posted: Tue May 06, 2008 6:11 pm Post subject: |
Thanks now I know  _________________ Dan
1979/924 N/A
©2008 |
