altern78ator bracket bolts
steeny
PostPosted: Mon Nov 19, 2007 2:54 pm    Post subject: altern78ator bracket bolts Reply with quote
anyone know off the top of their head the size and pitch of the bolts that hold on the rear alternator bracket (78 NA)
one of mine mine dropped out, taking the alternator ground strap with it, and its sort of important that i put it back on.
cheers
1978 924 N/A
she's gone.....
leadfoot
PostPosted: Mon Nov 19, 2007 4:48 pm    Post subject: Reply with quote
M8 X 18 according to the PET
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
PostPosted: Mon Nov 19, 2007 5:12 pm    Post subject: Reply with quote
1.5mm pitch IIRC
leadfoot
PostPosted: Mon Nov 19, 2007 5:26 pm    Post subject: Reply with quote
seems like a large pitch for an M8 ozzie... would try a 1.25...
leadfoot
PostPosted: Mon Nov 19, 2007 5:27 pm    Post subject: Reply with quote
probably right
RC
PostPosted: Tue Nov 20, 2007 5:48 am    Post subject: Reply with quote
Hang on steeny.
There are 2 types of top rear bracket. The one Leadfoot and probably Ozzie has is made from folded 3mm sheet metal. The one you have is the cast aluminium type and is 8-10mm thick IIRC.
With a washer and/or split washer under the head there will be insufficient thread with a 18mm bolt. Which you wont get unless you go genuine. 20 is standard but get a 25mm. Sure I`m using 25 on the thinner bracket anyway (with flat and star washer) as it is preferable to use the longest possible bolt. Get a 25mm and even though its a PITA screw it in without the washer and check it doesnt bottom out. Then fit the washer and tighten up.
Standard coarse thread M8 is 1.25 pitch.
Roger
