Scorpio
Posted: Sun Nov 04, 2007 1:53 pm Post subject: painting problems |
can someone tell me what im doing wrong. Im getting white patches/lines on my car surface as i spray paint it...it goes on shiny but as i do my next pass with 50% overlap these patches start to appear...could too much or too little thinner do this??.. .. Im using a gravity feed gun, thought that was the problem so i bought another one, which gave me a better spray pattern but still these white cloudy patches/lines..they dont buff out either they actually seem to get worse after cutting
originally i used a 1.4mm nozzle now a 1.7mm still same problems.
The paint is a black acrylic. If i were too guess ide say something wrong with air supply perhaps water vapour in the compressor line or too high humidty..although i know people who spray in high humidity with no problems.
Also ive heard conflicting views , one says lightly spray your spray room/ garage floor with water to prevent airborne dust particles, whereas others say keep room as dry as possible.??
any ideas?..techniques? _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!! |
PORSCHEV
Posted: Mon Nov 05, 2007 2:12 am Post subject: |
Tell me more about the paint you are using. Are you using the right activator and the proper reducer? What mix ratio are you using and what does the maker call for?
I would rule out water contaimination as that looks different then clouds. Is the paint solid black or does it have some metalics? _________________ 1976 924
1978-#53 "D" track racer. |
924aussie
Joined: 02 Feb 2006 Posts: 1009 Location: Chinchilla Queensland Australia
Posted: Mon Nov 05, 2007 11:27 am Post subject: |
Scorpio,
Go down to supercheap and buy the spray painting book. Done by the guy from NSW TAFE.
Enrol in a 6 week Spray Painting Course ... night time at Ithaca college across from the Broncos.
1.. What is the compressor you are using
2.. what is the brand of the thinners
3.. what is the brand of the Acrylic Laquer ... should be the same
4... what mixing ratio are you using
5.. What paint was it previously painted in
6.. If you have been spraying outdoors in the recent weather we have had it may be a humidity problem
7.. If it was indoors what was the approx temperature of the panels
Alan  _________________ green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1980 Fire truck Sold |
puddlejumper
Posted: Mon Nov 05, 2007 12:46 pm Post subject: |
Throw some pics up. _________________ If one does not fail at times, then one has not challenged himself.
Ferdinand Porsche |
Posted: Mon Nov 05, 2007 12:56 pm Post subject: |
How did you clean the surface?..could silicone from old wax be causing it? _________________ "..it's made in Germany. You know the Germans always make good stuff."
924aussie
Scorpio
Posted: Tue Nov 06, 2007 12:42 pm Post subject: |
THE PAINT IS SEPTONE ACRYLIC.
1 is to 1.5 paint to thinner ratio
They recommend a 2mm nozzle on the tin but i think my 1.7 even the 1.4 is sufficient enough.
The thinner was a different brand but as of yesterday ive gone out and bought a SEPTONE thinner aswell as a inline water trap
[/img]
THE DAMAGE
the photo looks alot worse then it really is but it illustrates the problem, im spraying my suzuki bonnet as practice before hitting the porsche, ive sprayed a couple of cars before and they turned out great (used different paints, prob wasnt as humid), im using the cheaper paint here $80 , 4 litres because the suzuki is just practice. I tried spraying just air onto the right corner to illustrate the effect , sprayed it as paint was drying and you could visibly see the cloudy bit forming, does this mean the air quality is bad..ie too moist or the paint and or thinner is bad? On the coat you see i did go overboard to illustrate whats going on, previous coats werent as bad but still shi7. overlap of coats was fine 50% overlap .The centre uneven bit is masked off blue strip
| Quote: | | How did you clean the surface?..could silicone from old wax be causing it? |
The surface was wet sanded then i used septone grease and wax remover so im pretty sure it ist the problem
| Quote: |
7.. If it was indoors what was the approx temperature of the panels |
Hey alan i was actually thinking of the ithaca spray course but 6 weeks is just a bit too much at the moment with other commitments. Im attempting the whole self taught method and have been reading up a fairbit, i dont seem to have any other problems but the white cloudy bands. Compressor is a 40 litre, perhaps slightly small but airflow pressure seems fine.
Ive tried a variety of different thining ratios from 1 to 1 all the way to almost 3 is too one..I was told the more thinner the better generally to an extent ( not for the environment though !). Ive been spraying indoors and yes it has been pretty humid...can says dont spray above 80% humidity, Today is 59% humidity and in the last week i dont think it got above 70%
| Quote: | Is the paint solid black or does it have some metalics?
its a solid black |
Here in brisbane a spray job costs in the thousands and ive asked around but apparently noone here does hire spray booths anymore..not good
Thanks all for the help!! _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
Posted: Tue Nov 06, 2007 1:41 pm Post subject: |
Apparently it's something in the air supply if spraying just air causes it.
Do you drain the compressors' tank after each use? Was the air line used for anything else since the last paintjob?- Maybe the line's contaminated with oil from the compressor..? Is the compressor using/consuming oil? _________________ "..it's made in Germany. You know the Germans always make good stuff."
924aussie
Posted: Tue Nov 06, 2007 2:39 pm Post subject: |
| Smoothie wrote: | Apparently it's something in the air supply if spraying just air causes it.
Do you drain the compressors' tank after each use? Was the air line used for anything else since the last paintjob?- Maybe the line's contaminated with oil from the compressor..? Is the compressor using/consuming oil? |
As smoothie says Air is air nothing else ...
Course is three hours once a week for 6 weeks of a night time 5.30 to 9pm
Replace the gun with an air duster / blower and see if anything comes out.
I have a portable spray booth but it only fits bikes in it at the moment. I am thinking of putting slide outs in it like a motorhome.
Scorpio
Posted: Tue Nov 06, 2007 2:41 pm Post subject: |
| Quote: | Apparently it's something in the air supply if spraying just air causes it.
Its a new compressor, i drain the tank before every use allowing water to drip out. and havent used the pipe for anything else. I dont think the compressor is consuming any oil. That lower right corner which i sprayed with air was straight after putting a coat of black on it..ie the paint wasnt dry, perhaps the air is fine and there is a problem with the thinner..im going to try the new thinner with the inline water trap...will the water trap also trap any oils? _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
Posted: Tue Nov 06, 2007 3:15 pm Post subject: |
Yes, the trap will catch oil and water. I use two, one at each end of the hose. _________________ "..it's made in Germany. You know the Germans always make good stuff."
924aussie
Posted: Tue Nov 06, 2007 3:42 pm Post subject: |
just curious .... what was the other brand and what was the ratio you mixed it at.
924aussie
Posted: Tue Nov 06, 2007 7:05 pm Post subject: |
PPG also known here as Dulux, ICI Duco etc
If you do this FREE online course you will notice that some parts are repeated ... just be patient
http://corporateportal.ppg.com/NA/Refinish/PPGRefinish/5-0-Training/5-7-OnlineTraining/
Online Training
Too busy to take time away from work to your increase your knowledge and hone your skills? Then consider taking of one of our PPG's online training courses. Now you can study at home, at night, on weekends—anytime you choose.
Here's a list of the courses currently available online. To learn more about a course, simply click a course title.
Course Titles
Color 21
Safety
Fundamentals
Undercoats and Topcoats
Repair Process
Distributor Troubleshooting
Elearning SAMPLER
PPG Color Variant System
Nexa Autocolor World Car Colour System
One Choice™ Plastic Prep System
Delfleet Essential
Actually the real reason of your problem is probaly that you are not using the recommended Spray Gun as per the Porsche Workshop Equipment list
Final Coat Spray Gun SATA Jet/B order number 3228
Posted: Sat Nov 10, 2007 4:42 am Post subject: |
| PSI? |
PORSCHEV
Posted: Sat Nov 10, 2007 6:13 am Post subject: |
| Scorpio wrote: | THE PAINT IS SEPTONE ACRYLIC.
Your not being clear enough on the mixing ratio.
If it were an acrylic lacquer I would think it should take an activator. The way I understand your ratio you mention it would be 1.5 liters of paint to 1 liter of thinner which would be very thin to spray. Most lacquers are 10-20% thinner.
I have painted hundreds of cars and I have never seen anything like that! Oil contaimination makes fish eyes...so it's not that for certain.
Water in the air line will form small droplets as you are spaying.
The product info also says "It is not suitable for application over air dry enamels or nitrocellulose lacquers. Septone Acrylic Lacquer is ideal for the DIY enthusiast due to its ease of application and quick drying properties." _________________ 1976 924
