michi924
Joined: 22 May 2007 Posts: 163 Location: Pontevedra, Spain
Posted: Fri Nov 09, 2007 5:30 am Post subject: Remove calipers without bleeding brake fluid. |
Hello. Is it possible or is it a nonsense? How can i do it?
Thank you. |
Martijnus
Posted: Fri Nov 09, 2007 6:05 am Post subject: |
remove them from the suspension or remove them from the car?
I believe I did it.
It's really complicated:
- take them off, but don't take off the brake line. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
michi924
Posted: Fri Nov 09, 2007 7:24 am Post subject: |
No, no.
I mean remove them from the car. |
michi924
Posted: Fri Nov 09, 2007 7:25 am Post subject: |
| Martijnus wrote: | remove them from the suspension or remove them from the car?
I believe I did it.
- take them off, but don't take off the brake line. |
joecitizennn
Posted: Fri Nov 09, 2007 9:39 am Post subject: |
Why do you want to avoid bleeding the brakes? It is so easy to do. I know people say that you can install clutch cylinders without bleeding (I never do it that way) but I would not do it with brakes. Brakes are too important. Bleed them any way you want, but bleed them. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
Posted: Fri Nov 09, 2007 10:00 am Post subject: |
Brake fluid should be changed every 2 years.
Rubber brake hoses should be replaced every 10 years. _________________ White 87 924S "Ghost"
Posted: Fri Nov 09, 2007 5:49 pm Post subject: |
| joecitizennn wrote: | | Why do you want to avoid bleeding the brakes? It is so easy to do. I know people say that you can install clutch cylinders without bleeding (I never do it that way) but I would not do it with brakes. Brakes are too important. Bleed them any way you want, but bleed them. |
+1 _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
michi924
Posted: Fri Nov 09, 2007 6:41 pm Post subject: |
I've changed the brake fluid recently, but now one piston is stuck in its hole. That's why i want to remove this caliper. |
DOCO
Joined: 04 Aug 2006 Posts: 1111 Location: Keswick Ontario Canada
Posted: Sat Nov 10, 2007 12:16 am Post subject: |
pull off the caliper thats stuck and plug your flex hose with a cap to advoid losing fliud.rebuild or replace the defective caliper .after its installed open the bleed screw and let it gravity bleed...ALWAYS keep an eye on your fluid resevoir and dont let it empty!after the bubbles disapear close up your bleeder screw.now you are going to have to bleed that side that you just removed the caliper.doing it this way will avoid you haveing to bleed the complete system.  _________________ Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
Posted: Sat Nov 10, 2007 7:37 am Post subject: |
If you are going to try to install a seal kit in the stuck caliper, make sure that you get the piston freed up before you remove the caliper from the car.
You can use the car's brake system to blow the piston free by removing the brake pad on the caliper piston side, then stepping on the brakes. Since the other three calipers will move the brake pads a very small distance (limited by the rotors), the rest of the fluid will be directed to the caliper with the stuck piston, and should blow it loose.
Make sure that the caliper is on the car (travel limited by the rotor), since the piston will move suddenly and quickly with great force.
As DOCO wrote, you can gravity bleed the brake lines if/when you remove a caliper. I start with the caliper installed, piston not fully retracted, no brake pads, and the bleed screw removed for maximum flow. |
michi924
Posted: Sat Nov 10, 2007 9:05 am Post subject: |
| Thank you for your answers. |
