fish62570
Joined: 03 Apr 2007 Posts: 54 Location: Burnsville,MN
Posted: Wed Nov 07, 2007 12:56 pm Post subject: 5 speed transmission |
I am looking on to my next upgrade and that would be to have a 5-speed transmission installed in a 78' 924 NA. I currently have the 4 speed and due to highway driving I would love to have the extra gear. What transmission would be available ,with the easiest install in mind? I will be replacing engine gaskets over the next few months(winter is coming). I would prefer to keep the car out of the salt in Minnesota's winter months. Also, due to the bad gaskets, is there anything else I might consider checking/replacing while the engine is being looked at?
Thoughts please.......... _________________ 924 work in progress |
endwrench
Posted: Wed Nov 07, 2007 1:18 pm Post subject: |
Your easiest option would be a 81 or 82 924 NA 5speed. This would pretty much bolt up with just a shift linkage change. The 82 turbo unit or a 944 trans will work also but you need to change out the torque tube and clutch disc.
fish62570
Posted: Fri Nov 09, 2007 5:15 am Post subject: |
thanks Todd for the quick response. With the availibility to keep costs down, would you happen to know what other Audi/VW cars might have this same transmission? If any. _________________ 924 work in progress |
