Where do I locate the Oxygen Sensor reset button on 1980 924
Robb Northrup
PostPosted: Thu Nov 08, 2007 12:16 pm    Post subject: Where do I locate the Oxygen Sensor reset button on 1980 924 Reply with quote
I replaced the sensor on Saturday, following the directions given by my trusty Haynes manual. But I could not find a reset button on the left inner fender as explained by the manual. I did find an odd plastic connector for the Oxy sensor wire, located on the steering crossmember. Could this be the reset button?
Robb
PostPosted: Thu Nov 08, 2007 12:25 pm    Post subject: Reply with quote
That's not it.
Follow the speedo cable from either end and you will find it. Unless of course someone removed it by installing a single piece speedo cable!
PostPosted: Thu Nov 08, 2007 2:11 pm    Post subject: Reply with quote
When you find it, the short end of a small allen key (say, 4mm) works great to reset it.
