Tiny
Posted: Sun Nov 04, 2007 5:33 am Post subject: fuel pipeand filter across top of the tank |
Hi Guys,
What's the purpose of this fuel pipe and plastic fitting that goes across the top of the tank?
thanks,
Tiny _________________ *****1981 - 924 - Auto - London, UK****** |
Posted: Sun Nov 04, 2007 5:53 am Post subject: |
AFAIK it is just a vent line _________________ 3 928s, |
johnathan1
Posted: Sun Nov 04, 2007 4:15 pm Post subject: |
Do you have a high-res version of that pic? I'm wondering if mine looks the same. _________________ -1977 924, 4-Spd...Gone
-1987 Toyota Supra Turbo, Pearl White, BPU, 300RWHP @ 10psi.
-1989 Mercedes-Benz 300SEL
WARNING: MAY CONTAIN TRACES OF AUDI OR VW! |
Tiny
Posted: Sun Nov 04, 2007 10:08 pm Post subject: |
Hi Johnathan,
Afraid not, as I didnt take this shot.
regards,
John Brown
Posted: Sun Nov 04, 2007 10:53 pm Post subject: |
The plastic tube functions as an expansion tank. Whether it's absolutely necessary I've wondered about as it is not very much larger than the same length of hose. _________________ John
80 931 - #931 44Cup
99 Escalade - tows track cars
Posted: Mon Nov 05, 2007 6:51 am Post subject: |
I had mine out last year and if it was cracked it would just have been a fuel line going across there. _________________ Porsche 924 1984 (UK import) NA
joecitizennn
Posted: Mon Nov 05, 2007 7:21 am Post subject: |
What year of car was that tank from? _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
johnathan1
Posted: Mon Nov 05, 2007 10:28 am Post subject: |
I have a feeling that the hoses connected to that plastic tube are leaking on my car...I am guessing I will have to drop the tank to replace those lines? _________________ -1977 924, 4-Spd...Gone
joecitizennn
Posted: Mon Nov 05, 2007 11:22 am Post subject: |
I can smell raw fuel from time to time on a full tank. I know that my sending unit is not leaking because i have lifted the cover when the smell was strong and looked at it. It was dry. If a 1987 924S has the above setup, that may be my problem. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold |
Posted: Mon Nov 05, 2007 1:16 pm Post subject: |
| johnathan1 wrote: | | I have a feeling that the hoses connected to that plastic tube are leaking on my car...I am guessing I will have to drop the tank to replace those lines? |
No- I did mine without removing the tank- look in the how-to section.
Cutting a hole is drastic but it worked. _________________ Porsche 924 1984 (UK import) NA
johnathan1
Posted: Mon Nov 05, 2007 5:19 pm Post subject: |
| Ozzie wrote: | | johnathan1 wrote: | | I have a feeling that the hoses connected to that plastic tube are leaking on my car...I am guessing I will have to drop the tank to replace those lines? |
Cutting a hole is drastic but it worked. |
WTF??? Is the fuel tank THAT hard to remove? _________________ -1977 924, 4-Spd...Gone
Posted: Mon Nov 05, 2007 5:30 pm Post subject: |
It is very easy to remove the tank.
You just have to remove the transmission and drop the exhaust first. _________________ Porsche 924 1984 (UK import) NA
johnathan1
Posted: Mon Nov 05, 2007 8:19 pm Post subject: |
| Ozzie wrote: | It is very easy to remove the tank.
You just have to remove the transmission and drop the exhaust first. |
Right then...i'll go look for my tinsnips!  _________________ -1977 924, 4-Spd...Gone
Posted: Mon Nov 05, 2007 8:52 pm Post subject: |
http://www.924board.org/viewtopic.php?t=17851 _________________ Porsche 924 1984 (UK import) NA
