Mike924
Posted: Thu Nov 01, 2007 6:23 pm Post subject: How about a 911 oil gauge? |
It has come to my attention that 911s are fitted with a combined oil pressure/temperature gauge. As some of the guys here have been considering fitting oil temp senders to their cars, this could be a neat solution:
1) it ought to fit in place of the current oil pressure gauge (2" diameter?)
2) 2 gauges for the price of one
3) maintains the standard 'Porsche look' of the dash
 _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Mike924
Posted: Thu Nov 01, 2007 6:32 pm Post subject: |
Here's an even nicer one, but judging from the number of warning lights ( ), it might not be a 2" gauge...
RC
Posted: Thu Nov 01, 2007 9:04 pm Post subject: |
Before you get too excited Mike did you notice that the 911 gauges read to 5 and ours go to 10 on the pressure scale. The unit of measurement is Kp/cm2 which approximates bars. Our engines generate a lot of oil pressure compared to other Porsches and have uniquely high reading gauges. Not only are the gauges different but also the senders (0-5, 0-10) and their respective resistances. Examination of the VDO specs on various senders will confirm this.
Roger |
Martijnus
Joined: 29 Dec 2006 Posts: 2019 Location: Netherlands
Posted: Thu Nov 01, 2007 9:44 pm Post subject: |
the second one would be quite nice... especially for me, I could use all those warning lights for my MS project... _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Killed her at the Nurburgring, Porscheless at the moment |
colin
Posted: Fri Nov 02, 2007 3:20 am Post subject: |
i tried taking my 10 bar unit and putting it in my S which has a 5 bar, didnt work, it was reading full 10 bar all of the time when at idle it sould be 3-4 ish _________________ 1979 924 parting ways
1987 924S
1987 parts car |
Mike924
Posted: Fri Nov 02, 2007 5:40 pm Post subject: |
Come, come, now. Surely no-one believes that the numbers on the guages have any objective meaning. (My oil gauge reads 1.5 bar with the engine off!)
I take the view that they're just 'indicators' - up is more..., down is less... Whatever collection of gauges you've got, you soon get the feel of where the needles should point and then spot the times when they're different (like when the earth strap falls off you're alternator... )
I was just a suggestion, to throw ideas into the pot... Only trying to help.  _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Mike924
Posted: Fri Nov 02, 2007 5:51 pm Post subject: |
| colin wrote: | | i tried taking my 10 bar unit and putting it in my S which has a 5 bar, didnt work, it was reading full 10 bar all of the time when at idle it sould be 3-4 ish |
It ought to be possible to match a more sensitive gauge (such as the 924 unit) to the sender with a resistor to limit the current through the meter head.
Going the other way (e.g. 911 instrument - 924 sender) there's not much you can do. A real pressure of 5 - 6 bar will read about 2 bar on the meter.
Or you could use a different sender. But then Roger's point about the 10 bar limit applies.
Can't have everything I suppose! *sigh* _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
colin
Posted: Sat Nov 03, 2007 1:02 pm Post subject: |
i think ill just leave mine alone and go out for a drive instead of wasting my time _________________ 1979 924 parting ways
1987 924S
1987 parts car |
Posted: Sat Nov 03, 2007 6:31 pm Post subject: |
| colin wrote: | | i think ill just leave mine alone and go out for a drive instead of wasting my time |
premium thinking ! _________________ Supercharger and EFI kits
Mike924
Posted: Mon Nov 05, 2007 6:02 pm Post subject: |
I think you've missed my point, Colin.
Some of the guys on some of the other threads are thinking of fitting oil temperature gauges and there was some discussion about where on the dash to site the gauge itself. The purpose of my post was to offer a possible alternative for their consideration.
Obviously, there's no point in changing over to a 911 meter just for the sake of it... _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
