skytrooper
Joined: 29 Aug 2007 Posts: 461 Location: Canandaigua, NY
Posted: Sun Oct 21, 2007 12:00 am Post subject: instrument bulb replacement |
| The bulb for my engine temp gauge is kaput. How do I go about removing the dash cluster so I can change the bulb ? |
Kevin D
Posted: Sun Oct 21, 2007 12:49 pm Post subject: |
That combi guage is just a friction fit with a rubber ring around the base of the gauge and a small white plastic key at 6pm. Watch for the plastic key when you push it out toward the steering wheel from behind the dash. Actually, I usually just pull my steering wheel anytime I start crawling under the dash. It makes it a lot easier to move around. You shouldn't have to remove the two screws that hold the dash pod in, but you can if you want more flexibility. _________________ '88 924S 3L 6sp RedRat
'92 Duc 900ss
'02 Duc 998 Carbon
'72 RD 350 |
Posted: Mon Oct 22, 2007 4:54 am Post subject: |
Disturbing 20 year old wiring, and the cracked dashboard is not a good way to go.
You can actually replace the bulbs from the back side if you slide the seat all the way to the rear, and crawl up under the dashboard with a strong flashlight. Then all you do is reachup and remove the blub socket for the bulb that is out.
Make sure that you replace the bunrt out bulb with one that has the same rating. I know that it is tempting to put in brighter bulbs, but melting the plastic bulb socket or damaging the instrument would not be good. |
skytrooper
Posted: Tue Oct 23, 2007 9:12 am Post subject: |
I will give the "reach" method a try
Thanks !! |
MrMoMo
Joined: 14 Mar 2007 Posts: 60 Location: Kingston, Ontario
Posted: Tue Oct 23, 2007 12:33 pm Post subject: |
| gohim wrote: | | slide the seat all the way to the rear, and crawl up under the dashboard with a strong flashlight. |
You make that sound waaaay to simple!! I was under there tonight replacing the light in the speedo, and attempting the one in the tach. I think if I broke my arm in about 3 places I might be able to get in more comfortably!!
Did manage to change the one in the speedo, but couldn't get the tach before my arms/neck gave out. I did remove the DME, which allowed me better line of sight. _________________ Bruce
'87 924S (project 937)
'87 924S parts car
'87 924S parts car
-Strewn amongst the other vehicular mass engulfing my property! |
