Ring and Pinion: options and problems
What gear ratio is the most fun?
stock
66%
 66%  [ 2 ]
low
33%
 33%  [ 1 ]
high
0%
 0%  [ 0 ]
super low
0%
 0%  [ 0 ]
super high
0%
 0%  [ 0 ]
Total Votes : 3
Cone_Eater
PostPosted: Thu Oct 11, 2007 2:00 pm    Post subject: Ring and Pinion: options and problems Reply with quote
I have recently found out that I have a ring and pinion problem. I thought it was the transmission but it's not. I have been looking into the whole gear ratio thing. The 924S has a gear ratio of 9:37 = 0.243. This is a fairly tall gear ratio. Correct me if I am wrong! I think in a transaxle you can change the ring and pinion to get a different ratio. Again PLEASE CORRECT ME IF I AM WRONG! I have been looking around at these and have found one that will lower the ratio to 4:11 = 0.364. Is there going to be any problems to change to this if I already have to replace it? (Other than gas mileage, Lol) I have found one through PowerHaus at Lightgearsahead.com Has anyone used this company?
1988 924S: Koni fully adjustables, Short shift kit, head work, exhaust, K&N, Jacobs ignition, Larger Injectors, Performance Chip, 928 wheels with cooper Zeon tires, Momo interior, Etc.....
If its fast enough to go... its fast enough to blow.
PostPosted: Thu Oct 11, 2007 5:04 pm    Post subject: Reply with quote
Close ratio 1-4, high 5th for highway cruising (a la early 944 NA).
PostPosted: Thu Oct 11, 2007 8:25 pm    Post subject: Reply with quote
yea...what you want is an early 944 NA gearbox. its a short gearbox(for a decently powered engine). its crazy...0-200 Kmph is incredibly fast....0-160 seem just an eye blink
Raceboy
PostPosted: Thu Oct 11, 2007 9:27 pm    Post subject: Reply with quote
924 NA Audi-type 5spd is even shorter gear ratio than 944 NA and it has proven itself handling more power and more reliable. Strange but true.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
PostPosted: Thu Oct 11, 2007 9:47 pm    Post subject: Reply with quote
very true...the 924 NA gearbox is even shorter...but unfortunately it does not go with any other TT/engine than the 924NA.
The NA gearbox that i have shifts way faster than any 944 gearbox that i have seen....i'd love a coupler that can mate the 944 TT to the 924 gearbox.
PostPosted: Fri Oct 12, 2007 1:43 am    Post subject: Reply with quote
Well, FWIW I just put fresh gear oil in Red (our S), and it is now shifting better than any car I have ever driven. It's a great tranny.
Raceboy
PostPosted: Fri Oct 12, 2007 2:12 am    Post subject: Reply with quote
There are many guys who have welded a coupler to use 924 transmission on 944.
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
Cone_Eater
PostPosted: Fri Oct 12, 2007 11:33 am    Post subject: Reply with quote
I think the trans is fine so I hate to do anything like change it. So what should I do about the ring and pinion?
