Tigger937
Posted: Fri Oct 12, 2007 1:25 pm Post subject: Turbo Replacement w/o Removing Head |
Anyone ever replace their turbo AND EM without removing the cylinder head? Can it be done? _________________ 1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box" |
macBdog
Posted: Fri Oct 12, 2007 2:43 pm Post subject: |
Yup, there are lots who will tell you otherwise but I can do it in 7 hours. _________________ 1979 931 with a 350 chev
1973 911E with EFI
Tigger937
Posted: Fri Oct 12, 2007 3:42 pm Post subject: |
| macBdog wrote: | | Yup, there are lots who will tell you otherwise but I can do it in 7 hours. |
Impressive, that's gotta be some sort of record. Or is it that much easier on a 932? Still, that's quick. _________________ 1981 931 (Concours)
924guy
Posted: Fri Oct 12, 2007 7:04 pm Post subject: |
been there done that, couple of times.. it can definitely be done, though i think its probably easier to pull the whole engine. might not be faster, but with it out, you can get to all the bolts much easier, and do a better job of getting more accurate torque values and such when putting it back together. its also a good option if you want to give the whole thing a once over, and replace the drain lines and other stuff thats hard to get from the top or the bottom.. _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Tigger937
Posted: Sun Oct 14, 2007 9:50 am Post subject: |
| 924guy wrote: | | been there done that, couple of times.. it can definitely be done, though i think its probably easier to pull the whole engine. might not be faster, but with it out, you can get to all the bolts much easier, and do a better job of getting more accurate torque values and such when putting it back together. its also a good option if you want to give the whole thing a once over, and replace the drain lines and other stuff thats hard to get from the top or the bottom.. |
Yeah, I hear ya and I'd really like to do it. No doubt that is the best way. Unfortunately garage space is at a premium right now. _________________ 1981 931 (Concours)
macBdog
Posted: Mon Oct 15, 2007 9:45 am Post subject: |
It is a frustrating experience. The first time I struggled bigtime - broke fingernails, plenty of skin off the back of my hands etc. The next time was a bit easier and by the fourth time I had a strategy for every nut.
A few of them required two universal joints and extensions on the ratchet. I'm sure torque values go out the window with so many transmission pieces in the way so I just do everything up "tight". _________________ 1979 931 with a 350 chev
1973 911E with EFI
rdjohnston50
Joined: 17 Oct 2005 Posts: 279 Location: sun prairie, wisconsin
Posted: Tue Oct 16, 2007 8:04 am Post subject: turbo replacement |
| When I bought this car, the turbo had been removed. I ended up putting another turbo back on w/o removing the head. It can be done. THe hardest part is getting the oil line to stop leaking at the top. |
