johnathan1
Posted: Wed Oct 10, 2007 10:33 am Post subject: What is this switch for? |
I noticed there is a switch in my 924 that has no label...it is just in front of the armrest, in between the ashtray and the armrest...it can be switch both left and right...anyone know what this switch does? _________________ -1977 924, 4-Spd...Gone
-1987 Toyota Supra Turbo, Pearl White, BPU, 300RWHP @ 10psi.
-1989 Mercedes-Benz 300SEL
WARNING: MAY CONTAIN TRACES OF AUDI OR VW! |
968rz
Joined: 21 Aug 2006 Posts: 537 Location: S. E. Wisconsin
Posted: Wed Oct 10, 2007 10:41 am Post subject: |
Could be the left/right electric mirror switch, the adjuster switch is on the drivers door (at least on my 79) _________________ Rick
93 968 coupe Amazon Green 4spd Tip (my DD) |
johnathan1
Posted: Wed Oct 10, 2007 12:18 pm Post subject: |
My car doesn't have electric mirrors... _________________ -1977 924, 4-Spd...Gone
Tigger937
Posted: Wed Oct 10, 2007 1:08 pm Post subject: |
It's probably just an extra unused switch, but it could also be for the rear wiper if you have that option installed. _________________ 1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box" |
johnathan1
Posted: Wed Oct 10, 2007 1:09 pm Post subject: |
My car has no rear wiper. _________________ -1977 924, 4-Spd...Gone
Tigger937
Posted: Wed Oct 10, 2007 1:18 pm Post subject: |
The only other factory option installed there is the headlight washers. _________________ 1981 931 (Concours)
Joined: 23 Apr 2006 Posts: 1650 Location: Sydney, Australia... mate!
Posted: Wed Oct 10, 2007 5:46 pm Post subject: |
I have a switch there that turns my radio on/off!! Damn crazy PO's
G. _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
924guy
Posted: Wed Oct 10, 2007 7:09 pm Post subject: |
pop out the ashtray, and take a look at the wires connected to the switch, if any. it is not uncommon for switches to be put in there without being hooked up (by prior owners to fill the space or for future use.) its usually pretty easy to determine if the wires are factory or after market if it is connected to something. factory wires usually have color coded tracers on them and neatly done connectors, where added on wires are usually a different gauge and solid without tracers, and the connectors arent as tidy (but not always.)
if there are wires that look factory, you try and reference them the wiring schematic for your year. if they dont look factory, just trace them back to wherever they connect under the dash and see where they take you... think of it as an adventure!
common uses for added switches beside the factory options are as power antenna control, 5th injector "hot start" grounding, fog light on/off and sometimes for "flashing" the fogs, and radio/amplifier control. _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
mgatlag
Posted: Wed Oct 10, 2007 11:41 pm Post subject: |
I have that same switch on my 77.5 and it does nothing. I have it now wired to be my garage door opener, pretty easy to do. _________________ Michael
'77 1/2 924 N/A- 5 speed Audi box
'04 Ford Taurus - gone!!
'92 Jeep Cherokee Laredo - gone!!
Porsche... better than tea with Miss McGill
(Slap Shot) |
Druman
Joined: 19 Mar 2007 Posts: 419 Location: Middleport, Ohio
Posted: Thu Oct 11, 2007 6:51 am Post subject: |
Maybe I missunderstood the location of the switch, but did you say it was in between the ashtray and the arm rest? If so I can't say that I've ever seen switches installed there, because they usually put them between the ashtray and the shifter, but there again I've been wrong before... Once... I bought an eraser.
7osh _________________ 87' 924S non-sunroof (Red) 45K miles
85' 944 "early" NA (Red) 130K miles
PORSCHE pisses excellence... |
