LBauer
Joined: 21 Mar 2007 Posts: 1 Location: Big Island, Hawaii
Posted: Mon Oct 08, 2007 11:39 am Post subject: Shipped my 924 from California to Hawaii-what happened? |
| I shipped my 79-924 from California to Hawaii. It ran great in California but once at sea level it is just having the hardest time idling. Does anyone know of any altitude adjustments necessary? Looking through my repair manual I sure don't see anything? Any Ideas????? |
Neil924
Posted: Mon Oct 08, 2007 12:18 pm Post subject: |
Yeah race cars have this problem a lot.
I don't know what the measurements are but I think the higher you go, the less air density and the cars run more lean. At sea level they use more air and need more fuel, I think.
Don't quote me now but you're on the right track. |
Neil924
Posted: Mon Oct 08, 2007 12:21 pm Post subject: |
| It's an N/A right? {No turbo} |
Posted: Mon Oct 08, 2007 1:27 pm Post subject: |
Yep, gotta richen it up a bit. _________________ Toofah King Bad
Posted: Tue Oct 09, 2007 2:52 am Post subject: |
yep, got the same problem....you just need to adjust it a bit. _________________ Supercharger and EFI kits
Neil924
Posted: Tue Oct 09, 2007 3:35 am Post subject: |
Yeah I checked it out, try "richening" up the car. A.K.A. give the car more fuel. Also check for a vacuum leak, something could have happened during shipping.
Could you pick up an Auto meter air/ fuel gauge at a local parts store, or do they only sell alcohol and surf boards in Hawaii? |
Tigger937
Posted: Tue Oct 09, 2007 4:04 am Post subject: |
Just head up Mauna Kea to confirm.
Mahalo and Aloha! A hui ho! _________________ 1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box" |
Posted: Wed Oct 10, 2007 3:18 am Post subject: |
That's interesting.
I always thought the air metering plate inherently took the air density into account based on the physics of how the fuel injection worked.
It's true carbeurators need this type of adjustment, but not fuel injected cars (mechanical or electronic), based on how they work.
The increased density of air at lower altitudes would cause an increased deflection of the air metering plate (for any throttle setting), causing a proportionally larger volume of fuel to be injected. Already compensated for!
Sounds like maybe a climate change has caused an air leak in your intake plumbing. _________________ 78 924 NA
5-lug |
