replacing bushings
berenlotr
PostPosted: Sun Oct 07, 2007 10:12 am    Post subject: replacing bushings Reply with quote
Hey i am changing out the bushings for the linkage on the tranny side. i am having a hrad time getting that pin in the coupler out, is there a trick to it or do u just drive it out of there
1979 924 N/A
PostPosted: Sun Oct 07, 2007 10:40 pm    Post subject: Reply with quote
Took me a minute, till I saw you have a 79! You're talking about the u-joint near the trans, with the large (10mm OD?) pin? Yes, that needs to be driven out, tap it out with a ball peen hammer. The center is wider than the ends (which helps contribute to the slop in the shifter).
berenlotr
PostPosted: Mon Oct 08, 2007 3:40 am    Post subject: Reply with quote
thanks. i cut a hole in the floor and found, surprise surprise, no bushing left at all. replacement ended up being pretty easy and man is that shifter crisp now, what a difference
1979 924 N/A
leadfoot
PostPosted: Mon Oct 08, 2007 3:34 pm    Post subject: Reply with quote
Can you post a picture of the hole, interested where you cut it...
thanks,
Leadfoot
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
berenlotr
PostPosted: Tue Oct 09, 2007 1:37 pm    Post subject: Reply with quote
i can't really get a pic right now i am back at college a couple hundred miles from my car . i cut the hole starting a couple inches up on the the hump as it inclines and it went down to the fortified part of the floor right before where the carpet starts
1979 924 N/A
leadfoot
PostPosted: Wed Oct 10, 2007 9:27 am    Post subject: Reply with quote
same place as 924RACR's then...
http://www.vaughanscott.com/construction/trans-hump4.jpg
are there any fluid line etc you need to look out for...?
thanks,
Leadfoot
