Missing???
porscheski924
PostPosted: Sun Dec 02, 2007 5:32 pm    Post subject: Missing??? Reply with quote
i changed plugs,wire, cap,and rotor and it still feels like it misses. could vaccum lines cause it to so that also??
1979 924 completly stock
PostPosted: Sun Dec 02, 2007 8:55 pm    Post subject: Reply with quote
In a word, YES...
A leaking vacuum line could cause a lean mixture, or the wrong ignition timing, or wrong idle speed.
Don't start twisting the idle speed, mixture, or timing adjustment untill you replace all of the vacuum lines if they haven't been replaced in the past five years.
PostPosted: Tue Dec 04, 2007 3:19 am    Post subject: Reply with quote
A miss could also be caused by a dirty/clogged fuel filter, if the miss is happening at times of high fuel demand.
78 924 NA
5-lug
