How do I adjust rear koni shocks?
joecitizennn
PostPosted: Tue Oct 09, 2007 10:52 am    Post subject: How do I adjust rear koni shocks? Reply with quote
How do I adjust rear adjustable Koni shocks from a 944?
924guy
PostPosted: Tue Oct 09, 2007 1:33 pm    Post subject: Reply with quote
mine have to be removed, extended, and you press a button and turn the head until they click, sorta.. your may be different depending on the model, but they have all the info you need in this pdf:
http://www.koni-na.com/pdf/tech.pdf
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
joecitizennn
PostPosted: Wed Oct 10, 2007 8:15 am    Post subject: Reply with quote
That explains the rears. I was able to adjust mine so stiff that I could barely move the shock by hand. Cool. I did not see a description of how to adjust the front cartrage type adjustable shock. They shocks are inside the mcpherson strut, but if you take them out they too say "adjustable". How do you adjust them?
Tigger937
PostPosted: Wed Oct 10, 2007 1:13 pm    Post subject: Reply with quote
If they're adjustable, there should be a flat pin sticking out the top of the strut tower mount under the hood that you turn clockwise or counterclockwise.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
