need advice on plugs
Vince Ponz
PostPosted: Mon Sep 17, 2007 12:54 am    Post subject: need advice on plugs Reply with quote
Those of you running carbs and a cam what plugs are you using?
I was blowing white smoke and we removed the head and nothing is wrong. Plugs were white..........too hot?
help.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
PostPosted: Mon Sep 17, 2007 2:15 am    Post subject: Reply with quote
Yellow-tan color and glazed insulator indicate too-hot.
White with minimal deposits is normal.
Excessive white deposits can be oil leaking past rings or valve seals, or too-thin oil viscosity.
Have a look, see - http://www.spark-plugs.co.uk/pages/technical/diagnosis.htm
http://www.mopar.com/m_maint_inspection_plugs_tune.html
Vince Ponz
PostPosted: Mon Sep 17, 2007 3:37 am    Post subject: Reply with quote
So far we removed the head and the gasket is fine and no leaks. I drained the gas as I had some race fuel in it and think maybe this was it. I will change the plugs.
Any other guesses.
79 931 Euro stock
88 924S SE
87 911 Targa stock
leadfoot
PostPosted: Thu Sep 20, 2007 2:38 pm    Post subject: Reply with quote
normally burning coolant is white
oil burning has a bluish tinge... sure of the color ??
with the higher octane were you running different timing??
unburnt fuel would still come out black...
more likely a cracked block or leaky head... possible the valve stem seals are starting wearing out...
Leadfoot
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
Vince Ponz
PostPosted: Thu Sep 20, 2007 10:37 pm    Post subject: Reply with quote
It was a very small failure in the head gasket.
79 931 Euro stock
88 924S SE
87 911 Targa stock
