Posted: Tue Oct 30, 2007 5:30 pm Post subject: Anyone ever seen one of these before? |
Came across this on E-bay: Zucc power flow.
It fit on top of the air metering plate and is claimed to improve the air flow around it.
Anyone seen this before or know anything about it?
Just curious... _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
johnathan1
Posted: Tue Oct 30, 2007 5:57 pm Post subject: |
I'm guessing it's just as effective as the "Tornado"? _________________ -1977 924, 4-Spd...Gone
-1987 Toyota Supra Turbo, Pearl White, BPU, 300RWHP @ 10psi.
-1989 Mercedes-Benz 300SEL
WARNING: MAY CONTAIN TRACES OF AUDI OR VW! |
Posted: Tue Oct 30, 2007 6:07 pm Post subject: |
er...Tornado? _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
johnathan1
Posted: Tue Oct 30, 2007 6:25 pm Post subject: |
You've never heard of the Tornado?? O_O
Maybe it's just a US thing...but it is one of the biggest gimmicks in history...It doesn't do anything that thee manufacturer claims...in fact in most tests, it was found to be a restriction in the intake path.
http://autorepair.about.com/cs/productreviews/fr/aafpr052002.htm _________________ -1977 924, 4-Spd...Gone
Posted: Tue Oct 30, 2007 6:49 pm Post subject: |
Sounds like the oz version of hiclone
http://www.fuelsaver.com.au/ _________________ Porsche 924 1984 (UK import) NA
peebles24
Joined: 27 Jul 2007 Posts: 43 Location: Terre Haute, IN
Posted: Tue Oct 30, 2007 8:55 pm Post subject: |
Looks almost Identical. _________________ 1981 924 Weissach, progressive rate coils, Dansk Polished S/S exhaust, free flow Cat, K&N filter
1991 Toyota FJ80 |
Posted: Wed Oct 31, 2007 1:09 am Post subject: |
Interesting.
It seems as though if it does what it claims, it'll cause your car to run lean. Decreasing the drag of the air metering plate will cause it to deflect less than a conventional plate for the same air flow, which is not what you want.
Also, it will increase the mass of the air metering plate, and without increasing the mass of the counterweight on the other side, this will again cause the plate to deflect a different amount than stock for the same air flow.
Gimmick extrordinare if you ask me. _________________ 78 924 NA
5-lug |
Posted: Wed Oct 31, 2007 1:11 am Post subject: |
So... the feeling is that it's not a goer, then?  _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
