A Little Clarification
BillA
PostPosted: Tue Mar 11, 2008 9:30 am    Post subject: A Little Clarification Reply with quote
I've got two sets of Turbo pistons on my workbench and would like to verify the set of numbers that are stamped on the outer flat portion of the top of the piston refers to the piston size (diameter)? Is that true, the 79 turbo pistons are stamped 86.45 and the 81 pistons are stamped 86.5 period. The Haynes manual does not refer to 86.5mm? Does the Haynes manual not list all of the piston sizes (Diameter in mm)?
Bill
BillA
1981 931
