J1NX3D
Joined: 06 Feb 2003 Posts: 1333 Location: New Zealand
Posted: Thu Sep 06, 2007 12:21 pm Post subject: remote oil filter and cooler |
I know quite a few guys are running this type of system on their n/a's. Can anyone whith any experience please check out this thread on my friends car and pm me any advice?
http://www.gpforums.co.nz/thread/283592/?s=
TIA  _________________ '86 944 |
Posted: Thu Sep 06, 2007 12:56 pm Post subject: |
I installed an oil cooler with remote filter mount on my NA some time ago. I have since removed it because the lines that came with it weren't steel braided, and one of them managed to get punctured somehow. I've been busy with other priorities on other cars, so buying $200 of line and fittings to plumb it in correctly on the NA just isn't that high on the list right now. In any event, I did NOT see any drop in oil pressure after installation. But I did notice about a 20-30C degree drop in the oil temp (I also installed an oil temp sender and gauge at about the same time). _________________ erstwhile owner of just about every 924 variant ever made |
Joined: 29 Jul 2001 Posts: 9136 Location: Royal Oak, MI, USA
Posted: Thu Sep 06, 2007 10:04 pm Post subject: |
No, there's no reason adding a cooler should reduce in a loss of oil pressure - sounds like somebody F'd up the plumbing. I'm running -10 hose for my cooler, works fine. Go big or go home; I run an 8x11.5" cooler, and need it. Street cars might be OK with smaller, sure.
I do run an oil t-stat, though I'm pretty sure it's not necessary in my case.
Sounds like a lot of confusion there about plumbing; do any questions remain? _________________ Vaughan Scott
J1NX3D
Posted: Fri Sep 07, 2007 7:20 am Post subject: |
No, not about the setup. hes really pleased with the info so cheers to ideola and 924RACR for that!!
hes now asking if anyone in NZ can get 12 sized oil coolers for cheap? lol! _________________ '86 944 |
