Posted: Sat Jun 23, 2007 10:39 am Post subject: Overheating Brainstorm. . . |
OK, so I got my car back from its "cooling system refresh", including new Performance Products radiator, H20 pump, t-stat, and hoses, and the cooling is worse. Here's all the clues I got, please give your theory.
The radiator leaked on arrival, due to poor solder joints between core tubes and end tanks. The rad was taken apart, and all joints were re-done. The mech said the old radiator had a lot of deposits. The AC consensor was damaged and left off (presumably giving better airflow to rad). My highest temp on the track used to be the third mark, now it slowly creeps into the bottom of the red (then I stop). If I keep the revs down, I can keep it out the red, but just barely. The bottom hose blew off while lapping. . .loose clamp, I believe. Both fans are coming on together at second white mark.
I am tempted to start troubleshooting by having the old rad serviced and reinstalling it. I am also curious as to whether the t-stat might have been installed facing the wrong way.
Any other ideas? Or questions? _________________ Toofah King Bad
steeny
Joined: 24 Nov 2005 Posts: 319 Location: Brisbane, Australia
Posted: Sat Jun 23, 2007 10:58 am Post subject: |
have you tried bleeding the air out of the system again? _________________ 1978 924 N/A
she's gone..... |
Posted: Sat Jun 23, 2007 11:09 am Post subject: |
could be air in the rad, too lean of a mix, or you could have some piping/hoses that are blocked. Take off the steel line which runs under the intake manifold and look in it to see if it is plugged at all. _________________ 3 928s, |
Tigger937
Posted: Sat Jun 23, 2007 12:25 pm Post subject: Re: Overheating Brainstorm. . . |
| Rasta Monsta wrote: | | The mech said the old radiator had a lot of deposits. |
Did you do a good job flushing all the crud from the engine too with cooling system flush? (and not into the new radiator )
+1 to what steeny said. Proper bleeding is very important.
| Rasta Monsta wrote: | | I am also curious as to whether the t-stat might have been installed facing the wrong way. |
Small disk should be facing downward (Assuming you have the correct T-stat.) Should have a smaller secondary disk at the bottom. Without the smaller disk, as Smoothie pointed out in one of his posts, the coolant won't circulate properly and will feed hot coolant back into the engine. _________________ 1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box" |
Min
Posted: Sat Jun 23, 2007 1:12 pm Post subject: |
From your description, it seems that a bit of guess and check is in order, we can assume all your new hoses are ok, your new water pump is probably ok. So what else did you change? radiator and t-stat. The other options are of course that the air was not bleed out of the system properly. So, Bleed it first, then swap in the old t-stat. Then based on those results, decide what to do next. Not a whole lot can go wrong with a rad so if its not visibly leaking, Its pretty much gotta do its job.
endwrench
Posted: Sat Jun 23, 2007 2:22 pm Post subject: |
Long shot but I have seen it happen before. Is the water pump new or rebuilt? I have seen wrong impellers put on or put on backwards. You just need to compare to the old one.
I don't know about the 924 heat gauge in general but mine is actually running about 210° at the 3rd mark. 1st mark is about 170° and the second about 190°. This was measured with an infer-red.
A slow-blow head gasket will do the same
Posted: Sat Jun 23, 2007 2:46 pm Post subject: |
| steeny wrote: | | have you tried bleeding the air out of the system again? |
Yes, multiple times while at the track today. Once even with the front of the car up on a friend's trailer.
| lizard wrote: | could be air in the rad, too lean of a mix, or you could have some piping/hoses that are blocked. Take off the steel line which runs under the intake manifold and look in it to see if it is plugged at all.
Thought about the too lean, but that doesn't represent a change in the last month. I'll check the pipe.
| Tigger937 wrote: |
Did you do a good job flushing all the crud from the engine too with cooling system flush? |
That was done as soon as I got the car last summer.
| Min wrote: | | So, Bleed it first, then swap in the old t-stat. |
Sounds reasonable. T-stat is next step, then.
| endwrench wrote: | | A slow-blow head gasket will do the same |
Now that would be sweet. . .and a real problem between myself and the mech that left the hose clamp loose. Oh, and water pump was a new unit.
Best diagnostic for that? Oil looks fine, coolant is hours old so it looks fine as well. . .test coolant for exhaust gasses?
Thanks all.
Tigger937
Posted: Sun Jun 24, 2007 1:40 am Post subject: |
Just thought of something, make sure your cooling fans are rotating in the proper direction, it's easy to get the wires swapped. Also, might verify the cooling fan switch is operating properly. Both fans should switch on at or before approx. 2nd (middle) white mark on the temp. gauge depending on temp. rating of the switch you have installed.
| Rasta Monsta wrote: | | endwrench wrote: | | A slow-blow head gasket will do the same |
Best diagnostic for that? Oil looks fine, coolant is hours old so it looks fine as well. . .test coolant for exhaust gasses? |
Watch for "ballooning" of the OEM coolant overflow tank as evidenced by cylinder head pressures leaking into the cooling passages from a blown head gasket. (I say OEM because I don't know if the 944 style would do the same.) The top of the tank will expand upward after the engine reaches operating temp. Shortly afterward, coolant will begin leaking past the pressure cap. (Once the operating temp. reaches the "red zone", you have very little time (minutes) before damage (i.e., cylinder head warpage) is done.) _________________ 1981 931 (Concours)
Min
Posted: Sun Jun 24, 2007 2:10 am Post subject: |
| Rasta Monsta wrote: | | Best diagnostic for that? Oil looks fine, coolant is hours old so it looks fine as well. . .test coolant for exhaust gasses? |
Leakdown test? ...
endwrench
Posted: Sun Jun 24, 2007 8:46 am Post subject: |
A CO test on the cooling tank would give you indication of a blown gasket or the best way may be to just apply air pressure to each cylinder and look for air bubbles in the overflow.
Posted: Tue Jun 26, 2007 12:45 pm Post subject: |
| Tigger937 wrote: | | Just thought of something, make sure your cooling fans are rotating in the proper direction, it's easy to get the wires swapped. |
Seriously? What is it, a plug that plugs on either way?
Checked, both fans are pulling quite hard. _________________ Toofah King Bad
462avi
Joined: 15 Sep 2006 Posts: 149 Location: Hollister, California
Posted: Wed Jun 27, 2007 1:00 am Post subject: |
How does the car run on the street, when you are not pushing its limits? The reason I ask is what if it is not a cooling system problem? How does your oil cooler look? Have you flushed it out? I would think that if you were to have a partially clogged oil cooler it is possible to see high engine temps. Also with the system bypass valve you may not see an indication of an oiling problem. Somewhere I remember see an article on engine oil and the effect it has on cooling. The water cooling system is basically for cooling the head and around the combustion chambers. The rest of the engine is cooled by the engine oil. Its worth a check _________________ 2005 C230K
2002 grand cherokee with 4.7L |
Chrenan
Posted: Wed Jun 27, 2007 1:17 am Post subject: |
Do you have an oil temp gauge? If not, you can buy a replacement dipstick with a temperature gauge built into the handle, might be worthwhile to see if your oil temps are getting too high. _________________ 1987 951 - M193 Version for Japan |
Posted: Wed Jun 27, 2007 1:58 am Post subject: |
The car does fine when being driven normally. I just got back from visiting Khal and Keno in BC.
I think the oil cooler is functioning. . .it gets too hot to touch when the engine is warm.
I am thinking now it has to be the "performance" radiator I installed. . .I'm going to have the old one serviced and put it back in for testing. It sounds odd, but maybe it isn't flowing enough. . .it did have problems in terms of assembly. . . _________________ Toofah King Bad
Posted: Thu Jun 28, 2007 4:12 am Post subject: |
| Rasta Monsta wrote: | | I just got back from visiting Khal and Keno in BC. |
Yup, it was good to catch up with you again, Rasta. And to finally see Shaggy! Nice car, drives well... hope the S is as good!  _________________ '80 924 Turbo |
