Short Block Differences
Tigger937
PostPosted: Sun Aug 26, 2007 12:20 pm    Post subject: Short Block Differences Reply with quote
Can someone confirm for me the differences in short blocks between the 924, 931, series I & II.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
PostPosted: Sun Aug 26, 2007 4:55 pm    Post subject: Reply with quote
924 - pistons- "cast light alloy", compression- RoW'78-'85 9.3:1, US'78-'79 8.5:1, US'80-'82 9.0:1
931 - pistons- forged, compression- both RoW & US '79-'80 (S1) 7.5:1, RoW '81-'82 and Italy thru '84 (S2) 8.5:1, US '81-'82 (S2) 8.0:1
Tigger937
PostPosted: Mon Aug 27, 2007 9:37 am    Post subject: Reply with quote
Thanks for that.
So the crank, rods and block are all the same, only the bearings, piston pins, pistons and rings are different?
1981 931 (Concours)
PostPosted: Mon Aug 27, 2007 9:48 am    Post subject: Reply with quote
Actually, I believe the bearings are the same also. Everything else from the rods on out is the same. (All 924NA-931 got forged rods according to the little booklet here.)
