| How many pounds of boost do I run? |
| 8-12lbs |
0% |
[ 0 ] |
| 13-16lbs |
0% |
[ 0 ] |
| 17-20lbs |
0% |
[ 0 ] |
| 20 or more lbs |
100% |
[ 4 ] |
| Total Votes : 4 |
Cone_Eater
Joined: 29 Jul 2007 Posts: 126 Location: Marshfield, MO
Posted: Tue Aug 21, 2007 1:43 pm Post subject: 924s Chip upgrade |
Hey everybody. I am about to turbo my 88 924s but I don't know what to do computer wise. It has already has fuel injectors to handle this. It has been chipped but what do I do to make the computer handle the new forced air? Any help would be great.
Thanks _________________ 1988 924S: Koni fully adjustables, Short shift kit, head work, exhaust, K&N, Jacobs ignition, Larger Injectors, Performance Chip, 928 wheels with cooper Zeon tires, Momo interior, Etc.....
If its fast enough to go... its fast enough to blow. |
Posted: Tue Aug 21, 2007 4:44 pm Post subject: |
i think that if you want to use the stock ECU for the boosted aplication you need that piggy back thing to be able to run it safely. At least thats what a friend of mine did when he supercharged his 944. _________________ Supercharger and EFI kits
Posted: Wed Aug 22, 2007 10:30 am Post subject: |
Why not get a 944 turbo fuel system and ECU? With stock compression, you'll be lucky to make it to 8 psi without blowing the headgasket. I'd start with 3 psi. _________________ White 87 924S "Ghost"
Posted: Wed Aug 22, 2007 12:46 pm Post subject: |
Coney, got any relatives in Richmond, BC? _________________ Toofah King Bad
Cone_Eater
Posted: Wed Aug 22, 2007 1:13 pm Post subject: |
| The engine and head have been gone through already so there are no worries there. I planned on running 10lbs or so. Where can I get the piggy back system? |
Min
Posted: Wed Aug 22, 2007 1:28 pm Post subject: |
Megasquirt it.
