Alternator Shroud Causing Grounding?
isuras2
PostPosted: Wed Aug 22, 2007 1:33 pm    Post subject: Alternator Shroud Causing Grounding? Reply with quote
When I installed the alternator shroud, then hook up the battery, I get some sparking, like the leads out the back of the alternator are grounding on the shroud. Has anyone else had this issue? My fix was to back out the bolt nearest to the wiring out about 1 turn. I also wrapped part of the shroud with electrical tape, but that didn’t help once the bolts were fully tightened.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
Rich H
PostPosted: Wed Aug 22, 2007 7:15 pm    Post subject: Reply with quote
I had a big spark whil;e trying to install my shroud. Forgot to disconnect the battery. I would check the wire routing and make sure its all nice and insulated.
leadfoot
PostPosted: Wed Aug 22, 2007 9:02 pm    Post subject: Reply with quote
Make sure your bolts that hold the shroud in are not too long, otherwise they will arc internally.
Leadfoot
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
isuras2
PostPosted: Wed Aug 22, 2007 9:55 pm    Post subject: Reply with quote
PET says M6x12 so I'll make sure I have those. I'll also check the wiring too.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
