Strut Inserts
isuras2
PostPosted: Tue Aug 21, 2007 3:00 am    Post subject: Strut Inserts Reply with quote
If I lower the struts and replace the strut inserts using the trolley jack method, there aren't any special tools needed, correct?
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Tue Aug 21, 2007 3:27 am    Post subject: Reply with quote
There is a special nut that holds the catridge inside the strut assembly. You can either obtain the special tool, or use a pipe wrench, or use a hammer and chisel to loosen it. I did the last, and it worked fine (a new nut should come with the cartridges).
Good luck!
PostPosted: Tue Aug 21, 2007 3:29 am    Post subject: Reply with quote
A 22mm deep offset wrench and 8mm open-end or whatever size allen wrench to loosen the top, then a pipe wrench to loosen the cap that holds the insert in..
for the top (click for larger) -
That insert cap can be tough to remove, so before loosening the top, with the wheel off and front jacked-up (spring extended) see if you can reach in between the spring coils with the pipe wrench and loosen the cap (just break it free - don't remove it until later).
PostPosted: Tue Aug 21, 2007 3:48 am    Post subject: Reply with quote
Oh yeah, forgot about that. If you have an O2 sensor socket, that works as well (you can turn the nut with the socket and crescent wrench while holding the allen key inserted through the socket).
Yikes, I am sounding like a bit of a hack, eh?
Also, on the wrench. . .I think I read somewhere that the 22mm deep offset can't be Craftsman. . .
PostPosted: Tue Aug 21, 2007 7:02 am    Post subject: Reply with quote
I'm glad now that I hopped on the metric offset wrench deal when I did years ago, - now they (HFT)'re only showing the SAE set (though it should include some metric equivalents like 1/2"=13mm, 3/4"=19mm, 7/8"=22mm-or probably close enough, etc.) -
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=32041
Benino
PostPosted: Tue Aug 21, 2007 2:21 pm    Post subject: Reply with quote
I got a 22mm offset wrench at the swapmeet. Works great. I've only had to use that wrench for strut insert replacements. I guess I was too cheap to buy the whole set. I use the pipe wrench to remove the insert nut. yup. I'm ghetto like that too:
1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA
RC
PostPosted: Tue Aug 21, 2007 2:35 pm    Post subject: Reply with quote
A rattle gun ( pneumatic impact driver) on the top nut makes it so easy. If you are replacing inserts it won`t matter using locking pliers or similar on the strut shaft. Tightening the new one is a different matter though!
Have not undone the cartridge retaining nut but mine appears to have been done previously with a pipe wrench.
Roger
PostPosted: Tue Aug 21, 2007 5:01 pm    Post subject: Reply with quote
There's no problem with using a pipe wrench for this job - provided you make sure you get good grip first time. It's only if the wrench slips that it causes damage...
