Posted: Wed Aug 08, 2007 1:58 am Post subject: 951 Injectors |
Red needs injectors, and I have a chance at some free 951 units. The 2.5 NA injectors are 24 lbs/hr, and the 951s are 36.
Will Red's ECU be able to control these properly, or do I need to match the flow rate?
TIA
rasta _________________ Toofah King Bad
-nick
Posted: Wed Aug 08, 2007 2:47 am Post subject: |
I'm 99% sure you need to stick with stock 924S injectors. The DME won't know your injectors are spraying lots more fuel other than from the o2 feedback, which will probably just make things ugly fast. _________________ 1980 931S
1991 964 C4 Cabriolet |
