Intercooler Efficiency Update
bass gt
PostPosted: Tue Aug 07, 2007 7:45 am    Post subject: Intercooler Efficiency Update Reply with quote
Guy's,
Managed to get to a track day today with the aim of getting some meaningful data from the car.
After a few runs i pulled the data logs and looked at the intercooler pre and post temps.
Now today was a lovely day, about 25 degrees C in old money.
So how does it work??
Well, the logs show intake temps before the IC of 90 Degrees. Now I'm not sure if the ECU data units are in deg C or fahrenheit, but the post IC temps were around the 36-39 deg area.
So all in all, it seems i am taking a major chunk of temp out of the charge air.
One note is that the temp sensors are of the standard Bosch type, not K probes, so they are not so quick to update, but i ran for over 15 minutes, with the log resoulution set to 0.1 sec, so there are reams of data!!
But by the seat of the pants, it felt very good. Quite a few people were slightly amazed at it's performance. One indicator was i pegged a Ferrari 355 spyder along the 1km straight, and he neither lost me, nor did i gain on him. And i know he had it pinned open!! However, i was in 5th by the end, and he was probably in 3rd!!
So, i think the upshot is that the bonnet vented IC is a major success. One last thing to do is increase the size and profile of the deflector, and i think it's good to go.
Regards,
Steve
Front Wheel Drive is the Devil's work.
endwrench
PostPosted: Tue Aug 07, 2007 2:01 pm    Post subject: Reply with quote
Great info Steve! Think I'll do a little "before and after" IC temp testing of my own. I can't datalog the before but I can measure it.
You basically have a rise of only 20°F over ambiant. That seems pretty phenominal! I forget, how much boost are you running?
Todd
bass gt
PostPosted: Tue Aug 07, 2007 5:01 pm    Post subject: Reply with quote
Todd,
The car was running at 15.2 psi of boost. As this was a track day, the car was pretty much flat out all the time!! It seems that my Garrett/KKKhybrid turbo is running very cool. I think this indicates the turbo is way too big for these engines.
steve
Raceboy
PostPosted: Tue Aug 07, 2007 6:17 pm    Post subject: Reply with quote
steve
No, I think the boost is just too low
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
leadfoot
PostPosted: Tue Aug 07, 2007 9:48 pm    Post subject: Reply with quote
Scary to think what they ran to get 375hp...
close to 30psi ??
Leadfoot
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
PostPosted: Wed Aug 08, 2007 10:16 am    Post subject: Reply with quote
21.75 PSI bored/stroked to 2.4 litre yeilded 450 hp for a 2050 lb car. Notice the cam driven water pump and the backward firing injectors.
http://im1.shutterfly.com/procserv/47b7d923b3127cce8627565caa3500000026108AZuGrlozZtE
http://im1.shutterfly.com/procserv/47b7d923b3127cce862750d1aabb00000026108AZuGrlozZtE
http://im1.shutterfly.com/procserv/47b7d923b3127cce86208ca0ca7100000026108AZuGrlozZtE
http://im1.shutterfly.com/procserv/47b7d923b3127cce86208dab0bd200000026108AZuGrlozZtE
PostPosted: Wed Aug 08, 2007 11:57 am    Post subject: Reply with quote
bass gt, what was the ambient temp when these readings were taken.
3 928s,
PostPosted: Wed Aug 08, 2007 2:07 pm    Post subject: Re: Intercooler Efficiency Update Reply with quote
78 924 NA
5-lug
bass gt
PostPosted: Thu Aug 09, 2007 12:13 am    Post subject: Reply with quote
Well, I've been back through the figures, and all seems correct. There was a rise in pre IC temps as the session went on, which is mirrored in a corresponding rise in the post temps. I guess this is IC heat soak. Now the logs show i was on or over 80% throttle for 70% of the time. So i guess the IC had little time to cool down in a non boost state.
Now by my rough calcs, my IC is operating somewhere in the region of 75% efficiency. Not bad. Now i think there is a bit of fine tuning to do, to imptove the airflow over the vent, and maybe look at a fine water misting device to give the IC a shot of the cold stuff, just to help of course!!
Steve
Fast924S
PostPosted: Mon Aug 13, 2007 10:58 am    Post subject: LOL Reply with quote
Just try this
http://www.machv.com/ntercooler.html
Rebuild COMPLETED, Many mods, better power, Just ask for info
