StienbargerR
Joined: 28 Oct 2005 Posts: 1362 Location: Richmond, IN
Posted: Wed Jul 18, 2007 7:05 am Post subject: Alternator Bushings- Affordable Sources? |
Does anyone know of a source for alternator bushings that are reasonably priced? I really hate to fork over alot of money to Performance Products. I only need the rubber bits.
Thanks,
Ryan _________________ 1978 924 NA
-250lb lowering springs, Euro Pistons |
Posted: Wed Jul 18, 2007 8:08 am Post subject: |
Try here and here. _________________ 78 924 NA
5-lug |
StienbargerR
Posted: Wed Jul 18, 2007 8:19 am Post subject: |
Thanks for the links tom, but I dont really want to do the skateboard bushing trick, i tried it without any luck
StienbargerR
Posted: Fri Jul 20, 2007 5:42 am Post subject: |
Bump.
Ps- What all do I need from Performance products? I just want the rubber bushings, no washers or anything
Posted: Fri Jul 20, 2007 11:33 am Post subject: |
If you don't like the skateboard bushing trick you'll likely not like this either, but in similar situations (needing rubber bushings) I just make my own by stuffing various sizes of hose that fit, one into the next to come up with something close with roughly the same OD and an ID that'll fit the bolt.
-But in your specific situation being in need of 924NA alternator bushings, I'd go with hard plastic replacements (delrin, nylon, or whatever). I believe the factory recommended replacements for the original rubber bushings are plastic, right? Autozone I know sells plastic stabilizer bar end-link bushings in a package of about 8 for $10-$15 that I'm pretty sure I'd be able to adapt to use as alternator bushings.. _________________ "..it's made in Germany. You know the Germans always make good stuff."
StienbargerR
Posted: Fri Jul 20, 2007 12:55 pm Post subject: |
thanks for the tip smoothie
Posted: Sat Jul 21, 2007 4:48 am Post subject: |
Why not try your local authorized Porsche Dealer?
Performance Products is only one a few Independent Sellers who has a contract to purchase directly from Porsche. But their prices are often higher than buying from a Porsche Dealer. |
StienbargerR
Posted: Sat Jul 21, 2007 5:16 am Post subject: |
Gohim,
Wow, thanks. That never even crossed my mind. I will get on that right away
Thanks,
