isuras2
Posted: Tue Jul 17, 2007 11:08 pm Post subject: Fuel Pressure Check |
I have a fuel injector pressure testor. I am a little lost as to where to hook it up. I was told at the fuel distributor, but not exactly where on the distributor. I was able to connect it to the CSV, but not sure if that is as accurate a spot. I was able to see the fuel pressure while in the drivers' seat though.
Thanks, _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
Posted: Wed Jul 18, 2007 8:34 am Post subject: |
The line to the WUR is the spot.
You need to check system pressure and control pressure.
If you shut of the line to the WUR it will tell you the system pressure and when open will tell you the control pressure. _________________ Porsche 924 1984 (UK import) NA
