stumped!!!
dman924S
PostPosted: Wed Jun 06, 2007 10:05 am    Post subject: stumped!!! Reply with quote
My car has been sitting in a garage for 6 years. The car is in mint condition. I have not started in the past 6 years. I tried turning it over ocassionally but got a no start each time. If I have spark to the plugs, correct fuel pressure,firing injectors, new 93 octane gas( i flushed the old gas out), correct cylinder compression, and a brand new battery, why will it still not start!
Druman
PostPosted: Wed Jun 06, 2007 10:19 am    Post subject: Reply with quote
What does it do when you turn the key? does it click or even attempt to turn over?
87' 924S non-sunroof (Red) 45K miles
85' 944 "early" NA (Red) 130K miles
PORSCHE pisses excellence...
dman924S
PostPosted: Wed Jun 06, 2007 11:12 am    Post subject: Reply with quote
the engine turns over but does not start.
PostPosted: Wed Jun 06, 2007 12:02 pm    Post subject: Re: stumped!!! Reply with quote
What is it?
Druman
PostPosted: Wed Jun 06, 2007 12:11 pm    Post subject: Reply with quote
Well, you need gas, spark, and air for an engine to run, and you say you have gas and spark, so maybe the problem is something with the air? Like a vacuum leak or a clogged air filter or something related.
7osh
Hoboceratops
PostPosted: Wed Jun 06, 2007 12:48 pm    Post subject: Reply with quote
Mayhaps a family of mice has taken up residence in your throttle body?
Just a thought...
1987 924S: Very much in love with it, even if it's all finnicky
PostPosted: Wed Jun 06, 2007 1:07 pm    Post subject: Reply with quote
If it's a 924S, stop trying to crank it immediately.
You need to get the timing and balance shaft belts replaced before you try to start the engine because they are way overdue for replacement.
If either breaks, or jumps a single tooth, you're going to be $3000-$5000 into major engine repair.
PostPosted: Thu Jun 07, 2007 1:00 am    Post subject: Reply with quote
Hey,
does it make a diffrence if you push the clutch?
Couldt be that the clutch is rust-baked somehow.
Also check the airpath all-the way.....and last but not least your exhaust
pipe, maybe some kinds put a big potato in it........
Greetings,
michi924
PostPosted: Fri Jun 08, 2007 7:58 am    Post subject: Reply with quote
Check the cold start valve. Sometimes the car won't start if there's a disfunction in the csv. Check the voltaje at the csv when cranking. Is should be +12. Check also that the fuel pump is working.
dman924S
PostPosted: Sun Jun 10, 2007 8:47 am    Post subject: Reply with quote
thanx for the help guys. I found out that the distributor cap was put on backwards. once I swithced it over it started immediatly! after 6 years its running again! Its a little rough right now so I am assuming its because its just working out all the kinks. I only started it for about a minute and then I shut it off. Could any damage have occurred because of trying to start the car multiple times with the distributor cap on backwards? also i saw a tiny bit of smoke coming from the headers or engine block (couldn't really tell). is this a sign of the head gasket going bad? or just dust burning off the headers? the timing belt was changed right before my accident, so could it have gone bad by just sitting around for so long? (sorry for all the questions)
PostPosted: Sun Jun 10, 2007 9:16 am    Post subject: Reply with quote
The dissy cap being on backwards wont cause any long term effects.
Smoke and dust being blown of the motor is normal until it heats up and should disappear.
Belts are a must- change them ASAP!
mjn
PostPosted: Sun Jun 10, 2007 2:18 pm    Post subject: Reply with quote
if you were trying to start the engine excessively make sure to drain out the oil as it has probably has gas contamination. also if it was really excessive you could have oil starved the piston rings. I know I'm a little late for this one but you should always put a about teaspoon of oil in each cylinder and manually crank an engine a few times ifyour not sure if its going to start.
1958 356 (sold)
1962 356b t-6 super (sold)
1989 speedster (sold)
1995 cab (stolen)
1994 mustang cobra
2001 ducati 748s r-mod track bike
2001 mv agusta f4s
