924S Custom Front Swaybar Pics
Kaos
PostPosted: Thu Jun 07, 2007 12:48 pm    Post subject: 924S Custom Front Swaybar Pics Reply with quote
I am starting a new thread for pictures of the swaybar mentioned in my autocross pictures thread.
These are some pictures of the swaybar setup that I made for my 1988 924S. I did the design and most of the fabrication, leaving the welding to a professional at my place of employment.
Components:
- 1-1/4" OD x 0.095" wall swaybar tube - Off the shelf from Speedway Engineering
- 48 Spline swaybar arms. Speedway Engineering, modified by cutting and welding for length and angle. These are probably a little hefty, and could go on a diet.
- 7/16" Teflon lined rod ends - for top link
- 7/16" Telfon lined high misalignment rod ends - for bottom link
- 1-1/4" ID Aluminum shaft collar - to prevent swaybar lateral movement
- 1-1/4" ID Energy suspension swaybar bushings and brackets- Bought these at the local Autozone. Modified with a small gusset welded on the edges
- Custom bracket to connect the swaybar bushings to the frame - made of 1-1/2" x 3/4" rectangular steel tubing. Connects to the two standard swaybar bracket bolts on the frame, as well as the front crossmember bolt. My measuring was a little off when I designed these, which explains the washers under the front crossmember bolt (I think you can see these in the pictures). A slightly longer crossmember bolt was required.
- Custom bracket to connect the rod ends to the lower control arm - made of 1-1/2" Angle iron. Connects to the stock sway bar holes in the lower control arm.
Well, thats it. I'm sure some more pictures of the system off of the car would be more helpful, but I'm not going to take it off the car any time soon.
Jon A.
macBdog
PostPosted: Thu Jun 07, 2007 1:24 pm    Post subject: Reply with quote
Thanks for those pics, I get it now. Looks like some heavy duty machinery.
1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote:
PostPosted: Thu Jun 07, 2007 5:00 pm    Post subject: Reply with quote
If that adjustment gives you the stiffness you want, you might consider a thicker bar, so your drop links can be closer to vertical.
PORSCHEV
PostPosted: Thu Jun 07, 2007 7:54 pm    Post subject: Reply with quote
For me the bottom line is...how did you find the performance. Was it noticeable? Looks like some nice machine / fab work!
1978-#53 "D" track racer.
Kaos
PostPosted: Thu Jun 07, 2007 9:04 pm    Post subject: Reply with quote
Here is the other thread I mentioned:http://www.924board.org/viewtopic.php?t=22317
I have two different bars to choose from; the 1-1/4"OD x 0.095" wall, and the 1-1/4" x 0.125" wall. I have tested them both, and the 0.125" thick bar is a little too stiff for the rest of my setup (stock M030 springs and rear sway bar per the autocross ruleset). Maybe If I ever jump up a class, and use stiffer springs, I will need to revisit the swaybar tuning.
I also like the fact that I can reduce the stiffness for slippery conditions - surface condition, temperature, rain/dry.
No machine work was required. Just a sawzall, bandsaw, grinder, drillpress, and welder.
As for the performance to my car, it definately helps. The idea is to stiffen the roll resistance of the front end so that the front tires have better camber (are more parrallel to the ground) during cornering. The stiffer front bar also helps to reduce any inside rear wheelspin, by transfering more weight at the front. How all of this translates into better performance for anyone else's vehicle setup, I cannot say. I haven't tested this on any car other than my own, but I do know it works pretty well for me (for autocross duty - I haven't used it at higher speeds on a racetrack). I have already tried the stock M030 swaybar (23mm?), and the Porsche 944 turbo front sway bar (27mm).
PostPosted: Thu Jun 07, 2007 9:40 pm    Post subject: Reply with quote
Very nice work, looks excellent! I've heard some complain about the quality of the Weltmeister bars, this looks like a great improvement...
genikz88
PostPosted: Fri Jun 08, 2007 11:52 am    Post subject: Reply with quote
That is fantastic. Thanks for posting.
Let me know if you decide to produce anymore of the brackets used to bolt the bar to the crossmember/chassis! The rest looks off the shelf stuff. GREAT idea you got going on there!
Chris
'88 924S
