Honda S2000 Spoon Sports F20C
Porsche924boy
PostPosted: Tue Nov 21, 2006 1:00 am    Post subject: Honda S2000 Spoon Sports F20C Reply with quote
Yes the cuvinete spoon engine, Known for it's "GODLY" redline of 14500 rpm's. The car cranks out arouns 230 Hp, and 225 Tq. So I know the transaxle can handle it Hp and Tq wise, but could it stand the high rpm's? This is just A thought I got, cause I'm a big fan of the 1995 (I think thats the year) Yellow Spoon Civic Hatchback. The yellow one, with the true carbon fibre hood. But yeah, Just rant and rave, just a thought to chew on.
What i own:
1995 Ford F150 Eddie Bauer 4X4
1995 F250 PowerStroke Diesel
Auto Technician Diploma
Diesel Technician Diploma
Andrew NZ
PostPosted: Tue Nov 21, 2006 5:18 am    Post subject: Reply with quote
You might have a few issues with gearing ....mmmm.....a 924 that could do over 60mph in 1st gear......it would probably get there in about 15 seconds too!!!
Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz
Porsche924boy
PostPosted: Wed Nov 22, 2006 12:44 am    Post subject: Reply with quote
So you saying, drop that engine in, I would proably hit 60 in 1st. In around 15 seconds, that would be nice. But I wonder what the thing would hit max. I say proably 175 (If i'm really lucky.) But see Doy you think it would work good? Plus you wouldn't have to shift at red line. But yeah keep the idea's a coming
What i own:
Andrew NZ
PostPosted: Wed Nov 22, 2006 8:09 am    Post subject: Reply with quote
Sorry, my sarcasm obviously didn't work!!
To put it simply, the gearing would be wrong for that engine to work.
My son's 1st generation civic has the wrong box in it and has a theoretical top speed of 250kph. It will never do that speed without 4 times the power (max speed is about 150 at the moment) and is slow to accellerate. When we swap the right box in it will only have a theoretical top speed of about 160kph, but will be able to get there easily, and will get there a lot quicker.
Andrew
1977 RX924 race car
no1gearhead
PostPosted: Wed Nov 22, 2006 1:07 pm    Post subject: Reply with quote
the honda motor spins the wrong way you would have 1 forward and 4 or 5 reverse gears depending on if you have a 4 or 5 speed. the only honda motor you might be able to use would be the one in the s2000 not sure which direction it spins. but hey if you want to go backwards really fast go for it
Martijnus
PostPosted: Fri Feb 16, 2007 7:20 am    Post subject: Reply with quote
Reduction stuff used on VW bugs to fit a subaru engine could work probably.
These reverse the rotation and can change the ratio between in- and output.
Dont know if they can handle the power, I believe they're used on the suspension on bugs, the 'final' drive so to speak.
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Porsche924boy
PostPosted: Sat Jul 21, 2007 5:40 am    Post subject: Reply with quote
Dumby I am talking about the Spoon Engine they drop in S2000's. Read the title.
What i own:
