Cleaning the crankcase breather
macBdog
PostPosted: Tue May 22, 2007 11:52 am    Post subject: Cleaning the crankcase breather Reply with quote
So I have read about the benefits of cleaning the engine breather on the side of the block but I am reluctant to pour gasoline down into my crankcase as has been suggested. How can you be sure all the gas is expelled from the sump afterwords?
What is the correct procedure? Can you spray some other bearing-friendly solvent under pressure from a degreaser gun or do you just pour it in and hope it breaks up the gunk?
If there are some good additions to this thread we can move it to the how-to section.
1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote:
PostPosted: Tue May 22, 2007 12:42 pm    Post subject: Reply with quote
Well, if the drain plug is off, you can bet that whatever drops of gas are left won't effect 6 quarts of oil once you refill. . .
Min
PostPosted: Tue May 22, 2007 3:02 pm    Post subject: Reply with quote
Personally the whole pouring solvent in my motor thing gave me the willies, so I just removed the breather with a screwdriver, and removed the mesh from it completely (using a drill and some pliers). In my case, it was so plugged that there is no way solvent would have fixed it anyways
Min
macBdog
PostPosted: Tue May 22, 2007 3:55 pm    Post subject: Reply with quote
You can do this with the engine in the car? I had no idea!
1973 911E with EFI
Tigger937
PostPosted: Tue May 22, 2007 6:13 pm    Post subject: Re: Cleaning the crankcase breather Reply with quote
One could always fill the crankcase with cheap 99 cent motor oil afterward, start up, idle for a few minutes and drain if there's a concern.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
PostPosted: Tue May 22, 2007 6:45 pm    Post subject: Reply with quote
It's certainly not easy to get at!
I've often thought I ought to do this, but I've been thwarted by the access problem every time! It would be a lot easier with the inlet manifold off...
PostPosted: Wed May 23, 2007 12:55 am    Post subject: Reply with quote
Hey their,
i replaced that 30 year old hose that is att. to the breather, and my car is much easier on high revs. then before.I could breath out better!!
I didnt touch the breather itself because in a book they wrote its not to fix with motor installed, or dismantled.See explo.view in repair manual.
Min
PostPosted: Wed May 23, 2007 1:53 am    Post subject: Reply with quote
yes, yes you can, I did it. I went from the top with a long screwdriver, pried it out, cleaned it up, and then wacked it back in with a mallet and a long peice of wood. However, it wasn't easy. And depending on your hose setup, it may require moving stuff, I personally didn't have to move anything ,I had clear access from the top (no wur, no distributor, and no cis junk in my way) Getting it back in is a bit of a problem though.
Min
Min
PostPosted: Wed May 23, 2007 1:54 am    Post subject: Reply with quote
I also noticed a very nice improvement in performance clearing out the breather. I never hooked it back up to vaccum though, thinking about getting a small vaccum pump.
Min
-nick
PostPosted: Wed May 23, 2007 2:46 am    Post subject: Reply with quote
It's a good idea to use a steel-reinforced hose for the breather - just to make sure it doesn't get squished or collapse.
When I cleaned mine, I just tapped on the ground until the black muck stopped coming out, then let it sit in gasoline overnight. Seemed perfectly open after that.
1980 931S
1991 964 C4 Cabriolet
Min
PostPosted: Wed May 23, 2007 2:51 am    Post subject: Reply with quote
I tried various methods for cleaning mine, including scrubbing, soaking, etc. Removing the mesh seemed like a good plan after none of that had much effect.
Min
PostPosted: Wed May 23, 2007 4:02 am    Post subject: Reply with quote
Well, I am staring at the PET and not really seeing what you guys are talking about. Could you elucidate for me? Is it a different setup for a 931?
I am wondering if I have the same issue, as my oil cap is leaking even with a new seal. . .
Min
PostPosted: Wed May 23, 2007 4:11 am    Post subject: Reply with quote
Underneath the intake manifold near the back of the motor is a hole in the block that has a pressed in metal cap. The cap contains a metal mesh, and is intended to allow crank case pressure to vent. The mesh gets clogged.
Min
PostPosted: Wed May 23, 2007 5:41 am    Post subject: Reply with quote
The breather itself (the mesh-filled metal cap at the rear-side of the block) is the same between 924NA and 931. After that, the NA just has a hose with a restricter orifice and dumps back into the intake (as I recall some attach at the airbox while others attach further downstream at a boot between the airbox and throttle.
-While the outlet of the breather on the 931 goes to the air-oil seperator which has a drain to the sump and an outlet to the airbox. If the breather on a 931 gets completely clogged, then the oil drain from air-oil seperator to sump will want to become your breather and you might end up with oil being sent the wrong way - up that drain + up the drain for the turbo on the other side of the engine. Most likely you'd just have a blocked, nonfunctional breather-air-oil seperator system though, rather than a major disaster with large amounts of oil overflowing the seperator. Plus you might have leaky seals and/or leaky oil filler and dipstick + you might have some smoking if the oil's backed up severely on the turbo drain side.
A quick unscientific test would be to detach the breather line from the air-oil seperator and blow through it with the oil fill cap removed then make a guess as to whether it's flowing freely enough or not. (This would be slightly complicated by the earlier 931 breather setup that used a Y pipe to connect the turbo breather and crankcase breather - in that case you'd have to disconnect the breather line at the Y so you could blow through just the one line that leads to the breather "cap".)
PostPosted: Wed May 23, 2007 9:51 pm    Post subject: Reply with quote
Actually, that's an interesting point, Rasta.
The picture in PET (illustarion 104-00) doesn't show the breather as fitted (to my car, at least). The part I've got looks like the bottom bit of part 9 (047 115 251), without the swan-neck pipe coming out and just a stub pipe instead.
