Starter/Compression question
Brockoli
PostPosted: Tue May 15, 2007 10:10 am    Post subject: Starter/Compression question Reply with quote
My 1977 924 with 110K kms on it wont start. I recieved it like this. I just fixed the:
timing
fuel pump
cold start valve
aux air valve
thermo time switch
battery
good spark
no air leaks I can find
injectors spray but not a perfect cone pattern
jumped the fuel pump relay
It hasnt run in atleast 5yrs, maybe 10yrs. It cranks over really slow. I think the starter needs to be rebuilt.
Question 1: Is there anything else mechanical that would cause the engine to turn over very slowly other than the starter?(other than the engine not running in so long)
I did a compression test and got 110, 120, 90, 85 psi. The last two scare me. But since the car hasnt run in a long time could the seals/gaskets be dry?
Question 2: Could the compression get better if I could start it and lube everything up via the oil pump?
Thanx for any help!
'80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
'79 924 Sebring Edition(Sitting)
!tom
PostPosted: Tue May 15, 2007 1:24 pm    Post subject: Reply with quote
Make sure you have a good ground between the starter and the battery. This usually goes through the engine, so there are several places for corrosion to build up and make for a poor electrical connection.
Check the power (positive) wire as well to the starter/solenoid.
78 924 NA
5-lug
PostPosted: Tue May 15, 2007 5:28 pm    Post subject: Reply with quote
If the engine is only turning over slowly it's unlikely that the compression test is going to be accuate. To lubricate the cylinders on an engine that hasn't been started in a long time, remove the spark plugs and squirt a little oil into each cylinder. Try doing the compression test again after this.
Edited to correct cr@p typing!
Brockoli
PostPosted: Tue May 22, 2007 9:35 am    Post subject: Reply with quote
I just got it running. It was the timing. My dad and I made a mistake when we reset the timing. Hopefully the compression goes up now that I can run it and get it to proper running temp.
PostPosted: Tue May 22, 2007 5:17 pm    Post subject: Reply with quote
Confused here.
How did getting the timing wrong cause the engine to crank slow?
