Alloy fuel tank
cleethorpes
PostPosted: Fri May 18, 2007 2:48 am    Post subject: Alloy fuel tank Reply with quote
Can someone give me an idea of what dimensions I'll need to get around 10 uk gallons. Obviously it will need to fit in the standard type location.....many thanks
'24 turbo with dodgy gt bodykit......needs a new home
PostPosted: Fri May 18, 2007 3:44 am    Post subject: Reply with quote
Here's a start - 1 Imperial gal = 3518cc, so 10 Imp gal = 35180cc
(from the back of the Haynes - "Imperial quarts (Imp qt) X 1.137 = Litres (l)" - so... 1 litre (1000cc) / 1.137 = 879.5 (cc's per Imp qt) X 4 = 3518 (cc's per Imp gal))
Pick a length and width in centimeters that'll fit the space, multiply those together, then divide 35180 by that number to get the height. (Or of course start with any 2 of the dimensions, then do the same math to arrive at the 3rd dimension.)
cleethorpes
PostPosted: Fri May 18, 2007 4:31 am    Post subject: Reply with quote
Are you the bloke from ' the pursuit of happyness ' ???
Cheers
